Dream Box dm800 no sky channels?
  • jasonf
    • Jun 2009
    • 78
    Hi guys having a problem with my dream box 800 can't get any sky channels i get the channel info at the bottom of the screen then the screen goes blank? any ideas peps???
  • smoggie
    • 863
    do you get any channels whatsoever? Have you tried a rescan.Is your cam active?
    • jasonf
      • Jun 2009
      • 78
      Yes get other channels just not sky stuff?
      • smoggie
        • 863
        is you cam active? what method are you using to obtain pay channels??
        step by step explain what you have done to obtain the encrypted channels
        • alom5
          • 1648
          seems like you are not able to unscramble the channel. do you have a sub .....of some kind?
          • jasonf
            • Jun 2009
            • 78
            ? not sure what u mean?
            • jasonf
              • Jun 2009
              • 78
              What & help?
              • RuberDuck
                • 1724
                how are you obtaining your channels. ie do you have a sky card in your receiver or are you using a cardshare ?.
                be carefull how you answer as cardsharing is a taboo subject on this and most forums.
                • jasonf
                  • Jun 2009
                  • 78
                  Its not a sky card? !!
                  • dctyper
                    • 2539
                    you have a pm
                    dc
                    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
                    previous life dm800hd and 500c on cable screw you nag3
                    • RuberDuck
                      • 1724
                      pitty as dumb people should not be allowed to own a dreambox. if your using a linux box you should at least learn how to use it before you steal channels.
                      • alom5
                        • 1648
                        sentiments shared.......maybe even try reading some of the stuff out there before asking
                        • Dudsy
                          • Sep 2011
                          • 6
                          DCTYER
                          I seem to be having the same problem. i cant get any channels but get all the information on the screen - what channel is on (also get the subtitles)
                          i have tried the CCam update but nu luck.
                          any ideas?
                          • SGTFlipFlop
                            • Sep 2009
                            • 1002
                            Originally posted by Dudsy
                            DCTYER
                            any ideas?
                            Do you get BBC1, ITV, Ch4 & Ch5 etc, If they show and the premium channels don't then your sub is ~~~~ed.
                            If you can't see the FTA channels then the problem is deeper like connections, dish problem or not set up the box correctly. More info is needed
