installing hdd new enigma
  • okmate
    • Jul 2011
    • 81
    Help guys
    i have a freecom usb hdd 320gb that i used to have installed on my dm800hd since then i have used it to store different things
    so have decided to format it and use it on my dm800 again
    i used to be able to record and use timeshift but god i'm having a right nightmare
    first off whats the correct filesystem i should used
    the dm800 is recognising the hdd but when i initialise it takes forever and hangs
    also timeshift pause is also not working
    please help guys
  • okmate
    • Jul 2011
    • 81
    any one no what format a usb hdd should be for a dm800hd
    need a good starting point
    thanks guys
    • micflair
      • 275
      It should be a case of whack it in an go mate. The dm800 formats it to what it needs. Is the dm800 recognising it for a start? I cant remember if you have to initialize it first or not..
      • Rodbouy
        • Jul 2010
        • 1320
        You can get the box to format it or use this tool. fat32format (2).zip
        Then all you need to do is mount the drive.
        • owengrey
          • Dec 2010
          • 89
          Some images dont format the drive properly even though the box recognises the hard drive. easiet way is to remove drive and format it with ext3 not fat32 or ntfs .
          i use gparted which can be googled.
          just remember fat32 and ntfs are windows format, dreambox is linux so you wont go far wrong if you format ext3
          • okmate
            • Jul 2011
            • 81
            thanks mate i did actualy sort it i downloaded swissknife formated the hdd to fat32 plugged it back in and the dm800 done the rest all sorted thanks for your your time guys
