Can I permanently remove NAR( running commentary) on DM 800 clone
  • iggy
    • Sep 2011
    • 61
    I'm using dreamelite Phoenix edition on DM 800hd clone.
    When watching sky movies there is running commentary. I can turn it off via remote by pressing yellow or blue ( I'm not bear the box now).
    But when I reboot box it is back on.
    Is there a way to stop it permanently from running?
    Cheers
  • SGTFlipFlop
    • Sep 2009
    • 1002
    Goto Menu, setup, system, A/V Settings
    Set AC3 default to Yes
    This will leave a few channels needing changed manually, MTV, Challenge and a few others
    • lincsat
      • 1228
      Usually when you select the correct audio channels, then restart Enigma2, it remembers the setting.
      • SGTFlipFlop
        • Sep 2009
        • 1002
        Next Bouquet change forgets the setting I'm sure
        • southpaw
          • 2233
          was just gonna say
          In AV settings go to audio and change it to AC3,
          narrotor is mostly in mpeg so this should disable it
          sarg beat me to it
          • lincsat
            • 1228
            It's been a while, I know they are remembered on a Vu+ Duo using Blackhole
