Ordered Dreambox DM800se
  • skronk
    • 188
    Hi lads,
    Faffing about too long trying to decide what to buy.
    Got up this morning and thought...to hell with this.
    Took the plunge and ordered my dreambox.
    What I need to know now is....what cables do I need for it?
    Think maybe USB to 232 plug (female) . Is this correct if loading from laptop ?
  • southpaw
    • 2233
    tbh mate , if you check what your loading you wont need any additional cables , the rs232 connection is used when ~~~~ ups are made , its your back-door if you flash a dodgy image , check what your flashing (if yaoxin bought box it will be sim2.10) and you be fine without extra cables , only cable/connection you do need is ethernet cable
    good choice btw , you will enjoy your new box
    • skronk
      • 188
      Ordered from Ruby at L&W Industry (Shenzen) on the recommendation of a member here.
      Thanks for your input.
      • skronk
        • 188
        So I flash with USB stick then ?
        What size required ?
        Just trying to find out what I can before the box comes.
        • crazi
          • Mar 2009
          • 7
          no it'll probs come preflashed.. it no longer has a rs232 port but a mini usb ... use sunray to flash bootloader.. then u put box in dhcp mode.. (holding power in whilst switching on)
          then flash over network using 192 page
          Regards
          • southpaw
            • 2233
            Regards
            didnt realise it never had rs232 connection , just checked mine and your correct , only has mini usb for recovery
            • neilus0
              • Oct 2011
              • 24
              DM800SE
              Hello all. I'm new to this and hoping to make some new friends and learn a bit too.
              I've just ordered a Clone DM800SE from ebay. I hope this was a good choice??
              http://www.ebay.co.uk/itm/New-Dreamb...item4cfac31d42
              As far as I have read, I need to download and install a suitable image for this. I'm looking for advice on which image and installation instructions.
              Also looking to setup ccam (i believe) this is what its called.
              I'm using an old sky dish with dual lbn
              Thanks in advance
              • alom5
                • 1648
                you should've got it from china and saved yourself aat least ?40
                • neilus0
                  • Oct 2011
                  • 24
                  Well I guess this is the mistakes one makes when new to something.
                  Thanks for the advise, so now I have the DM800SE would you be able to help me set it up?
                  • blueflash234
                    • Mar 2009
                    • 904
                    its okay buying from china but you would have import tax to pay on top of the price quoted or maybe had it removed by customs who seem to work with dream stopping clones coming into some ports in uk, buying from uk is safer option, good box you will get many years of happy viewing with it
                    • southpaw
                      • 2233
                      New Dreambox 800HD SE PVR - dm800hd se freesat sky | eBay
                      Thanks in advance
                      the box will come pre-flashed , if you wish to change the installed image there is a poll here regarding best image
                      dish setup info http://www.digital-kaos.co.uk/forums...-dm800-143072/
                      how to flash new image http://www.digital-kaos.co.uk/forums...-dm800-122157/
                      cccam can be downloaded via tspanel (although there is more to it than downloading the cam , you will need something to go in the config)
                      you may wanna familiarise yourself with dbe http://www.digital-kaos.co.uk/forums...-guide-167275/
                      settings can be found here , thanks to sgtflipflop
                      good luck !
                      • alom5
                        • 1648
                        there are many who have received theirs without the import duty etc.
                        some have now canged their box name from dreambox to avoid any issues with being confiscated as well.
                        but it's ok if you got it and your happy that's the main thing.
                        with regards to setting up the box.................just hit the search and you will see all the fixes for pretty much any problems you may come across...........and if you don't find what ur looking for....just post and a;l here are pleased to help.
                        ulimately though.....you wiull have to pay about to get it to how you want it. everybody has different tastes an all that...
                        • neilus0
                          • Oct 2011
                          • 24
                          I received my DM800SE today.
                          Very nice is has the dreambox logo on the front etc but clearly is a clone
                          I plugged everything in and fiddled with the menus to select 28.2 Astra (old sky dish) and ran a scan.
                          Picked up hundreds of channels.
                          Its running enigma 2 OS
                          Couple of questions
                          1. Can I keep enigma 2 OS, just install Ccam and setup?
                          2. What is SIM201 exactly and how can I find out what my box has as I cant find any ref to in on the specs?
                          Many Thanks
                          • saj1985
                            • 785
                            how much did you pay for it if you dont mind me asking?
                            Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
                            • alom5
                              • 1648
                              Couple of questions
                              Many Thanks
                              you can just install cccam and away you go. also the sim will be 210 and not 201. not heard of any 800se coming sim201 mate.
