info
  • canford
    • Aug 2010
    • 263
    #31
    Thanks, do you a good set up guide from turning the box on etc
    • canford
      • Aug 2010
      • 263
      #32
      Thanks, do you know a good set up guide from the point of turning the box on for the first time etc and are there any updates which you should not install.
      • southpaw
        • 2233
        #33
        the box will come pre-flashed , if you wish to change the installed image there is a poll here regarding best image
        POLL _ WHICH IS THE BEST IMAGE FOR DM800SE SIM210
        dish setup info ### guide for setting up non usals for dm800 ###
        how to flash new image how to flash a DM800
        cccam can be downloaded via tspanel enigma2 TSpanel plugin,everything you need for your image
        you may wanna familiarise yourself with dbe DreamboxEdit Guide
        settings can be found here , thanks to sgtflipflop
        SGTFlipFlop SKYUK Bouquets - Updated Regularly
        good luck !
        • canford
          • Aug 2010
          • 263
          #34
          Thats just what the doctor ordered,thank you.
          • neilus0
            • Oct 2011
            • 24
            #35
            EPG
            I've had my dreambox for 1 day and with the help of the kind people here ive made great progress
            I've installed bouquet channels for sky UK
            However i cant get the EPG to work
            there is NO EPG button on the dream remote?
            Can anyone advise on how to get a sky uk EPG setup
            • southpaw
              • 2233
              #36
              @ neil , you can download "cross epg" from tspanel or other download panel , reboot box then config it , go menu>setup>crossepg
              best to use a usb stick to store the data ,
              when you have completed the crossepg setup , a good interface for displaying it is "coolmans epg" , again download via tsp or other d/l panel
              good luck , and well done in getting as far as you have
