No UK channels Dreambox 800HD
  • subcriminal
    • 17
    Hi, I set up my dreambox yesterday but I'm not recieving UK channels! I've had a search around but being new to tinkering with satellite gear I'm at a bit of a loss. So if anyone could point me in the right direction it'd be appreciated!
    I have a Dreambox 800HD pro, bootloader 82, Enigma II, dreamelite 1.33d Sim 2.01.
    I've managed to install cccam, edited the cfg and tuned around 600 channels on Astra 28.2E. I have a fairly weak SNR (between 50 and 60) as I still need to set the dish up properly.
    If I press the TV button and list all channels some have white progress looking bars on the left of them. I can view these channels and also some channels without the bar next to them. When I scroll down to a channel, on the right the text is either in German or French and the Audio is in either language when viewing the channel.
    It's all a bit of a mess! I can't find any UK FTA channels either.
    I'm wondering if either the supplier of my C: lines doesn't support Sky UK as well as they say or if it's a problem with the bouquets saved on the box. It was preconfigured when I bought it. Although scrolling through the 'all channels' menu I still can't find anything with English Audio!
    I'm not expecting a magic solution, just some advise or direction as this box has a bit of steep learning curve to it. Cheers!
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    looks like as you say, the dish isnt set up properly.. youre prob pointing at 19.2.. THINK this carries some uk tv channels..
    • subcriminal
      • 17
      Thanks, I'll get it set up with some proper gear then. I used satfinder in the menu on the dreambox, chose Eurobird1/Astra 28.2E and it locked ok after tweaking the dish around in the general direction of everyone elses. Just the SNR is a bit poo.
      Edit: So... I assumed if I used satfinder on the dreambox it would only show signal from the satellite selected. If I chose 28.2E and pointed it at 19.2 would that show a signal?
      Last edited by subcriminal; 17 October, 2011, 20:52. Reason: Thought of something else.
