New Black Dreambox Remote cant pause live tv anymore ? Dm800pro
This topic is closed.
  • lombard
    • Aug 2008
    • 793
    Hi, I have a DM800 Pro, installed OpenPLi 2.1 , installed Hdd, all working fine can record etc.
    weird thing is i got a old silver dreambox remote, which lets me pause live tv when press yellow button,
    i now got a new remote black one, its got extra layout of buttons for pause, play etc when i press pause get icon , like its saying cant do that.
    is there some driver or plugin that makes it work with black remote ?
    I attached picture
  • andy91
    • Aug 2010
    • 3583
    I thought the only difference with the remotes was the new ones didnt have an audio and pressing the yellow button was the answer.
    I wonder if its just another button needed to press for it to work?
    Andy
    • lombard
      • Aug 2008
      • 793
      pressing yellow button on black remote goes into audio selection,
      really is fustrating
      • Fano
        • 331
        Andy
        The Timeshift button is the play/pause button on the black remote (Below the green button)
        Took me a while to figure it out but its a better idea than the yellow button in my opinion.
        • lombard
          • Aug 2008
          • 793
          i know where the button is just doesnt work on black remote, but works on silver remote, seems i need keymap.xml for black remote, im using openpli 2.1 image
          • alom5
            • 1648
            help button - then start timeshift. this will pause the channel. then use the yellow button to unpause and pause again.
            • lombard
              • Aug 2008
              • 793
              got it working, another top member on another forum gave this and works now on black remote and silver remote works too, dont know why this aint included in images ? cause it works for both perfect
              Im using OpenpLi 2.1 was told might not work for other images
              send this to usr/share/enigma2 know to be working with openpli but not sure regarding other images so backup the one you have in your image now before sending this one in
              • Fano
                • 331
                It works fine on my black remote under Dream Elite Phoenix 2 ,no modding required.
                • lombard
                  • Aug 2008
                  • 793
                  must be already included in image, i changed from dream elite phoenix 2 because it glitched too much when recording and when pausing and then resuming channels like sly sports hd , since trying OpenPLi 2.1 no more glitches prefect now
                  I always thought high bitrate hd channels were too much for dm800 to handle, but it aint since going to OpenPLi
                  • remixxx
                    • Oct 2011
                    • 17
                    Awesome Lombard.
                    I was having the same problem since yesterday when i received the black remote from ebay.
                    Now i have it working again also on my openpli 2.1 image with this keymap
                    • bugger0815
                      • Apr 2012
                      • 4
                      Had exactly the same problem, the new keymap solved it - timeshift with play/pause button works like a charm. thanks!
                      • eliw
                        • May 2012
                        does pause, pause tv straight after press.. or do you still have to rewind first before you can pause ?
                        • shahn1
                          • Dec 2011
                          How to put the keymap on the box
                          I guess you have to ssh to the box and manually put in the /usr/share?
                          • tfredly
                            • Jul 2012
                            Do I need to set up anything on the box or should it work by default as long as the remote keymap is correct?
                            • southpaw
                              • 2233
                              whack your keymap in and away you go mate , no extra configuring needed
