download settings list,ye must have been in options to check ip is working so go to ftp,receive from dreambox,open the settings list)send file to dreambox,then reload setting on dreambox top right
open dcc press telnet on left hand column youll see temp folder open that then in right hand window youll see a drop down menu press that and find the folder with the tspanel ipk in it from your computer click that so it now shows in big window below then in the middle you see two arrows highlight the ipk then press the bottom arrow the tspanel ipk should now show in the left big window.now depending on your image you need to find the manual installer and install from there.
