Network setup?
  • jmjc0112
    • Oct 2011
    • 47
    Network setup?
    Hi everyone got my powerline adapters now but having a bit of trouble setting up a network.
    in test network im getting the following
    ip address x unconfirmed
    nameserver x unconfirmed
    my router is a Huawei echolife 521
    any help would be appreciated.
    800se with 320gb hd
    NewEnIgma2 SAT4FUN
  • mast
    • Nov 2010
    • 1027
    Hi
    Not sure as been ages since I set mine up but have you gone through the setup process for the adapters....pairing them together etc.
    • jordigirl
      • Oct 2011
      • 716
      did you follow the instructions via the set up disk that comes with powerline adaptors, it you have should no problem there quite straight forward
      • jmjc0112
        • Oct 2011
        • 47
        The comtrent 902 powerline adapters are plug and play. You basically turn off router and turn back on and the recognise themselves.
        Dreambox recognising
        lan connection connected then green tick
        local connected then green tick
        DHCP enabled then green tick
        800se with 320gb hd
        NewEnIgma2 SAT4FUN
        • mast
          • Nov 2010
          • 1027
          Hi
          Yeh thats right but you havent mixed them up have you cos one should be the access point which serial no ends in A which is the one thats connected to your router.
          The other one is the end point, this would be used to connect to box, just check to be sure.
          Failing that reset both and setup again, thats if you have the setup instructions. if you havent got the instructions you should be able to download them if you cant let me know and Il try and upload them.
          Regards
          • jmjc0112
            • Oct 2011
            • 47
            OK got it sorted, comtrend instuctions f2%k?d up only had to keep config button pressed until status button turned red constantly on the additional adapter then it turns green. NOT carry out the additional steps.
            Checked status by 192.168.1.2 to enter comtrend config and all adapters showing as connected.
            A small battle is won but the war isnt over.
            800se with 320gb hd
            NewEnIgma2 SAT4FUN
            • mast
              • Nov 2010
              • 1027
              Hi
              Glad you got it sorted and now youre on your way. As you say there`l be a few more battles yet.
