after reading the hole sticky about ts panel i really dont no were to start can some one make it more clear for me
thanks in advance
does this help mate,
tspanel loading info
you load this addon after the image of your choice is flashed
open the dcc and click [TOOLS] then [packages]
in the green section on the left of the panel
a list of the packages on your dreambox will upload
under the list are two bar strips [update package list]
and [upload package] click upload package bar a window will
open find and click on th tspanel file then click open on the
window the file will now load on your package list and will give
the loading info in the protocol pane under the package list.
once loaded,close the dcc and re start your dreambox when it
re boots you will find the tspanel in your menu list ready to use
and get to the extras for your image, like cams/config /skins etc:
the other way to load it is by opening the dcc and
d/left clicking the tmp folder in the left pane to open the folder
then you highlight the tspanel in the right pane and use the arrows
to send the file into the tmp folder then you close the dcc and with
your remote you press blue for this image and from the list find
manual install>ok and you will see the addon in the panel click ok
and load the addon and once loaded re start the image and you will
find it as above ready to use.
with some images there is no manual install feature so load as above,
how to find the cccams configs and all other extras
menu>tspanel>ok and first go to addons>ok
allow it to upload from the server then from here choose the cams
you want ie: 2.0.11 21.3 21.4 2.21 and cccam cnf file after selecting each cam >ok
after it has loaded do this for all cams, you then re boot the box
this is for genuine dreamboxes and images. for clone boxes or the vu boxes
you use the cams etc from there section in the tspanel list only
you can see and change cams you have loaded in the emu manager section
Please Read Carefully!
edit , -due to my one finger typing benny beat me too it ,
you can install the ipk using dreamboxcontrolcentre , DCC ,
download the file and unzip it (7zip is free and works great)
this should give you an ipk file type save it to a location on pc and remember location
load up dcc
make sure its connected to box via network
go to tools on left side on dcc
go to "ipkg packages"
click upload package - browse to file diectory andupload the unzipped file (in ipk format)
click update package
check telnet screen in dcc look for "install complete " or somethin similar
reboot box
iv loaded ts panel and got completly new image or something and to top it off no tuner is found i use to have dmm dreamelite v2.0 now its enigma II or something like that can i delete the enigma2 ipk and have what i had before
help !!!
thanks in advance
It is always wise to look ahead, but difficult to look further than you can see.
help !!!
thanks in advance
what do you mean a new image?
did you have a image flashed and set up
with the free to air chns opening before you
loaded the tspanal?
Dont think deleting the ipk is going to revert it back to what you had before, think you`l have to reflash preferably an image with tspanel allready preinstalled.
No relation between installation of TSpanel and error tuner not found,The later issue is related to incompatibility of type of dreambox with the installed drivers
if you have original dm800se install the original drivers from TSpanel and reboot dreambox,if you have sim2 dm800se just install sim2 ssl84 ipk from TSpanel/addons/sim2 addons/sim2 secondstages and reboot dreambox
but before doing that you should be sure about your dreambox
