Does anybody know how to install TSpanel on a newnigma2-dm800se-10-4-ramiMAHER.nf image, i have followed the info above and it shows thats its installed in dcc,but upon reboot its not there in the menu,i have tried both ways.Even in the newnigma2 sub menu were it gives you the option to install via a pugin, it will just not have it.Any idea guys.
Install problems
right. you need to do a reflash mate as something gone wrong somewhere.
which version are you using. use the ssl84 version and has tspanel already on it.
definately all works as well.
reflash mate. save your channels list and any other stauff.
reflash and be setup in a matter of minutes.Comment
use dreambox edit to save channels list...and any ftp progs for your other files such as cccam.cfg.
i think you can also save your configurations through the system tools menu.
i don't bother with that.
only files i save are the cccam.cfg and the channels list....
i have not used that version of the image either so couldn't say if ts panel and stuff works or not.
the ssl84 version in downloads i know works well.
if you are using windows....you need go start - run - cmd- press enter.
this will open up your command prompt window.(new black window)
type telnet 192.1681.xx your ip address of box.
this will open up and say something like opendreambox
dm800se login: (type) root (enter)
if set a password it will ask for password. enter that then you will get
root@dm800se:~# (this is where you enter the command mfaraj has put in his post)
i take it flashing the image again didn't work??Comment
pkg install -force-overwrite /tmp/tspanel ipk file name
