Streaming?
  • canford
    • Aug 2010
    • 263
    Streaming?
    Hi guys nearly all set up, just need a good tutorial or point in the right direction on how to stream movies from laptop/PC to dm800se,thats if it can be done.Thanks.
  • mfaraj57
    • 557
    i wrote this since longtime for dm800 but should apply to dm800se
    The experiment done under these conditions
    window 7 ultimate 32bit
    pc vlc version 1.0.5
    dreambox vlc player plugin 2.5
    dreambox image: merlin-excalibur 20-2-2011 76d
    Follow the pictures
    pc vlc settings
    dreambox vlc player plugin setup
    • mfaraj57
      • 557
      conitinue
      • canford
        • Aug 2010
        • 263
        Thank you will give that try later on today.
        • pento123
          • Jun 2011
          • 74
          What an excellent guide, and what a helpful guy!
          Thanks mfaraj57
          • canford
            • Aug 2010
            • 263
            Keep getting errors the vlc player has installed right and its in the nemisis 2 sub menu,but when you click on it this is the message i get Error loading playlist into server 1:<urlopen error[Errno145] connection timed out, any idea whats gone wrong,thanks.
              Make sure you have the correct ip in Vlc for the pc you are streaming from, also make sure your firewall is not blocking Vlc
              • canford
                • Aug 2010
                • 263
                At the moment its blocking dns server does that matter
                • southpaw
                  • 2233
                  If you got all your media in a folder with sharing enabled just use "network browser " to mount it, se can stream natively, no need for vlc or addons,
                  If you got no network browser in the network tab of menu, you can download from download panel
                  • canford
                    • Aug 2010
                    • 263
                    Not having much luck with that either,do you think there are any router changes i will have to make in the settings to get this to work.
                    • southpaw
                      • 2233
                      no router settings changes needed mate , just ensure the folder with the shares has sharing enabled
