DM Home Install
  • marcus1975
    • Jul 2011
    • 248
    DM Home Install
    Hi
    i am looking for someone who can help me set up my Dreambox 800HDse! i have spent the last 4 days (and nights) fiddling and playing however i am unable to make it function!!!! any help would be much appreciated especially if you are able to come to my home and help as i have already used much information from emails and messages without much joy. thank you I live near Stafford st18
    [I]Dreambox 800HDse,SUPERIOR DARK MOTOR METAL GEAR DiSEqC 1.2 ,Gibertini 1m Satellite Dish,FaVal TWIN LNB 0.1dB Universal Edition V2 HD SD TV
  • micflair
    • 275
    Originally posted by marcus1975
    Hi
    Okay pal, where do you need to start here? First job, pick an image. I personally use the newnigma2 one. There is a thread about in sticky's I think with the images. Choose one, then we will go through flashing it with you.. take it slow and you will be up and running in no time.
    When you say you `cant get it to function' what do you mean?
    • marcus1975
      • Jul 2011
      • 248
      hi
      It came new from supplier with image & cccam installed IHCV.
      i cannot activate you know what i have tried everything all types of programs and look for the file in dcc but no look.supplier tell all passwords are as default.I cannot even install new image as bootloader wont load on pc when Dm is inj stop mode ready to flash. Very frustrated
      • jmjc0112
        • Oct 2011
        • 47
        Have you managed to get your dreambox ip address?
        Try reseting to factory default and going thru stickys
        800se with 320gb hd
        NewEnIgma2 SAT4FUN
        • southpaw
          • 2233
          What do you mean by this? You don't need to load anything on PC except use a web browser
          • marcus1975
            • Jul 2011
            • 248
            yes i have my ip it looks like i might have to do factory reset
            and start again. Whould be nice if some one could come round and help.I would pay for them to set it up for me and show me a few things
            Best regards
            • marcus1975
              • Jul 2011
              • 248
              Easy cccam set up programs
              • Mjolinor
                V.I.P. VIC
                • 1093
                If you got it from a supplier with CCcam already installed are you saying you bought it in a supposedly working state?
                If so then do not factory reset it.
                • marcus1975
                  • Jul 2011
                  • 248
                  yes i did buy it set up i just cannot active all channels you know what And i cannot install new image
                  Help
                  • Mjolinor
                    V.I.P. VIC
                    • 1093
                    So more info is needed to tie down what your problem is.
                    Start with: Do any channels work, BBC, ITV etc
                    • marcus1975
                      • Jul 2011
                      • 248
                      all fta channels work on 28e problem is i cannot find where the cccam.cfg stored i cannot find it in DM edit
                      • micflair
                        • 275
                        Okay mate, do you have dcc up and running? Cccam.cfg is in the etc/ directory..
                        dm edit is not for that job. Download dcc from here and run that, then you can find and edit your cccam.cfg file..
                        • marcus1975
                          • Jul 2011
                          • 248
                          hi
                          file does not exist i have looked and looked
                          i am stumped
                          • micflair
                            • 275
                            Jeez louise.. use this mate..
                            • Mjolinor
                              V.I.P. VIC
                              • 1093
                              Do you know how to telnet?
                              If so telnet into the box and search for it, for sure it should be in /etc/ or maybe /var/etc/
                              Presumably you have the box connected to your network, do you know it's IP?
                              If it is connected to your network and the network settings in the setup work ok when you test them then you can install a plugin to display what CCcam is doing on the TV without having to go in the ethernet.
                              If you know the IP of the dreambox put it into a browser, do you get the web interface, if so then put "ip":/16001 in the URL bar of your browser, if CCcam is running then this will give you the status of it. (IP is the IP of the dreambox)
