hdd probel
  • comber
    • Sep 2009
    • 69
    hdd probel
    new dm 800hd came with 205g internal hdd ,,open pli image
    changed image to Dreamelite-BlackHole no when i try to format hdd keep getting greenscreen of deathwas able to use ftp to format
    but the recording wont stop ..
    timeshift wont work either
    all worked when i got it
  • 00360362878
    • Mar 2010
    • 488
    You need to format the hard disc to Ex3. Download ubuntu operating system and write to DVD. On sartup of your pc you will get the option to boot via dvd drive, so with the disc in the drive before you switch off your pc, boot using the disc, let it run, you will then be given the option to install or try, click try. Once it has loaded you will be able to format it there, but make sure you format to Ex3 or you wont get a full HD movie on there. If you are not sure google the (How to)
    Good luck!
