hi guys, can i ask a small question ??? any one know why you get a 404 not found when flashing a dream 800 via web browser ???
cheers
Power off box
Hold power button at front in
Switch power back to box and wait till it says *STOP* on oled
Look at what ip address it has assigned in the oled
Type this into your browser
This should take you to firmware upgrade page, if you get it taking you to the dreambox webcontrol page with a red 404 error on it then reset all your network and adapters and make sure dhcp is switched on in your router settings.
JoK
thanks m8 that is what i did and when i put in the ip addy i get this enery time ???
