ok im new to the dreambox se ive input all the write details in dream up my ip and dreambox ip but it does not let me falsh it says uploading completing waiting for response but nothing happens so i tried bootloder and then tried flashing a image and tried a few images but had the same message on dreamup saying now calcualting checksum and i waited for 2 hours or so nothing happened so i disconnected it and my box from the start since i updated it by mistake is stuck on R01:NO CA FOUND i looked threw stickies and everything.
fed up need help
**************************************************ok im new to the dreambox se ive input all the write details in dream up my ip and dreambox ip but it does not let me falsh it says uploading completing waiting for response but nothing happens so i tried bootloder and then tried flashing a image and tried a few images but had the same message on dreamup saying now calcualting checksum and i waited for 2 hours or so nothing happened so i disconnected it and my box from the start since i updated it by mistake is stuck on R01:NO CA FOUND i looked threw stickies and everything.
this could sound daft but are you using the correct
dreamup version for your box.Please Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
Uploading completing waiting for response on Dreamup usually means try a different version . Newer is not always better m8. Make sure the image your flashing is the correct one for your box ie Sim 2.01 or Ferrari.
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
the blue light flashes and it says downloaded on the led screen but then the led swtches off and the blue light is on but nothing is displaying in the led this is after i flashed the file sucessfully ive unpluged the wire etc but left the internet network cable in?Comment
after the it's loaded have you re booted the box with the switch
on the back, if yes do you get anything does the box fire up and
do you see anything on the tv from it. some images turn the oled off
and they need setting in the display set up from the menu to get back on.
also sim2 and ferrari use there own dreamup versions a genuine se uses a
genuine 1.3.3.9 dreamupPlease Read Carefully!
FTP config file to var\etc
im to old for this forgot everything use to be good at dreamboxes well the is going to soung silly i have flash fxp to ftp files when it says connect it gives me these lists that i have to input address etc
Server or Url:
User Name:
Password:
Remote Path:
Proxy Server: set as defult or can be changed to proxy not needed
Port:
what details do i put in here my pc ip is 192.168.1.208
dreambox ip is 192.168.1.200 and the port on pc is not 21 its COM1 So what do i fill in the boxComment
feel silly to be a newbie on this dreambox se
