wrong time on 800se clone
  • alanbk
    • Aug 2008
    • 59
    #61
    Horray
    Used your settings and did as you suggested above and the box is now keeping the correct time. Thanks a million. I will try and put a backup image with all the settings in the download section.
    • DigiEddie
      • Jan 2012
      Didn't work with me.
      • lombard
        • Aug 2008
        • 793
        #63
        I noticed the DM800se which have time issues on standby , when going into system information in box the Front_processor_3 which had time issue the one without issues its Front_Processor_1,
        • alom5
          • 1648
          #64
          I've used this and don't seem to have any time issues
          • benny/9
            • 1964
            #65
            try this way
            i had this clock problem for a long time
            and found this works and the clock keeps time on standby
            first class now. first load the npt conf file i added in a earlier post
            in this thread, then load everything this way
            using the dcc> ftp> double left click> etc folder
            then double left click> enigma2 folder then send
            the npt conf file in the enigma2 folder,
            then from the ts panel sim2 addons>ok pluggins>ok
            load the dvbtime_03_r0_02.10.2010 pluggin then set the clock
            from the tspanel system tools>ok time-date changer to the correct setting
            and re boot now if you look in the box menu you should see the gp2 dvb time settings with the ntp-server autostart: on and the clock should keep time
            Please Read Carefully!
            • lombard
              • Aug 2008
              • 793
              #66
              hi, anyone having time issues can you please check in image , system information and tell me what your Front_Processor_Version is ? and if having time issues,
              as i noticed Version 1 dont and version 3 does, so wanna know if its that.
              • alom5
                • 1648
                #67
                Mine is version 1. Had problems with it before but for the last few weeks since the ntp stuff all working.
                I don't know anything about the front processor or what it is...but all my boxes seem to be version 1. Is that something to do with image?
                • benny/9
                  • 1964
                  #68
                  this dm800se is the first clone iv'e ever had
                  and i got it to test again'st the genuine model
                  for quality etc: and both boxes show the same
                  Front_Processor_Version 3 and the genuine does'nt have
                  any time problems with any image. plus i have merlin 3
                  on both boxes so unless images change the processor version
                  i cant see that having any bearing on the time problem
                  i think i will try the clone on a different image and i also got
                  a ferrari sim with this box so i will test there image as well
                  • IAmATeaf
                    • 591
                    #69
                    I've got front proc 1 and haven't had a problem, am using OpenPLi.
                    • alom5
                      • 1648
                      #70
                      How are you finding the testing going Benny regards quality between the clone and original?
                      • benny/9
                        • 1964
                        #71
                        the quality is as good on the clone as the original
                        for picture sound menus remote etc, i have had a few problems
                        with some clone images green screen etc, the box case
                        is a bit more flimsy and not as good finish as the original
                        and i have read reports that a few have damaged the service port
                        when using the a/b mini usb cable but that could be heavy handed users
                        but generally at the price a fair buy, i want to test a clone vu+duo
                        i keep reading these are even better than a dreambox and use original
                        images
                        • lombard
                          • Aug 2008
                          • 793
                          #72
                          Hi, was just wanting to clear that as i have had 3 boxes dm800se all latest rev d6 front usb, the ones that had time issue was the Front_Processor_Version_3 and the one that had no issues was Front_Processor_Version_1
                          so wanted to clear that, i did install dvb timer from tspanel which sorted problem out on the ones that gave time issues,
                          so what do you guyz think is causing this ??
                          • IAmATeaf
                            • 591
                            #73
                            Mine is also a rev6, purchased around Xmas time.
                            • _wizard_
                              #74
                              Time problem
                              I am having the time issue on dm800se clone. Is there any news on fixing the issue or should I try one of the already above tested methods?
                              Regards
                              _wizard_
                              Norway
                              • benny/9
                                • 1964
                                #75
                                Regards
                                _wizard_
                                Norway
                                the way i posted a fix earlier in this thread works spot on
                                with the merlin 3 sim 2.10 image and the box has kept time but
                                if you re image you will have to load it again,but now i have
                                a vu duo clone so the dm800se is going on the bay,
