Can someone help please ?
How to flash dm800 se with dreamup
To Manualy update firmware on a DM 500HD and the dm800se hd models
via mini-usb service port & Lan Network
Items required:
1) A TO B mini-usb male to male [same as a camera USB] & Cat5 Network Cable
2) if you have a genuine model you can get the latest dreamup 1.3.3.9
you can also find the usb driver here if needed
(USB to UART Bridge Virtual COM Port (VCP) driver)
[if your model is a clone use the sunray version of dreamup]
Process:
1)first on the Dream 500HD/dm800se turn off with the switch on
the rear panel
2)next connect the cable for its part mini-usb port and
"Service" of the Dream 500HD and the USB to a USB port on your PC
and also the Lan Cable from your Router
3)Just plug it in, the PC will detect new hardware connected to the system:
4)The PC will ask the driver for this new component,
Windows 7 will download the driver Automaticly for you
the driver is cp210x usb to uart bridge controller
5)Open the Windows Device Manager,
and you will see the new hardware installed,
will appear as COM port (even a USB cable).
In the following example, is recognized as the cable into the port COM4.
6)next opened the universal DreamUP 1.3.3.9 [this is the latest version]
and select the update COM port (like any other model of Dreambox).
At this point, we choose the COM port that we appeared in the previous step
(COM4 in this example).and make sure there is a tick in the use network box
7)Press the Connect button the DreamUP universal panel and then go to the
dreambox and power it up to turn on again now the Dream 500HD/800se will
now to start up loading firmware.and once compleated the dreamup loader will
go in to HTTP mode you then click the flash button and find the correct image then on the window click open and it will load on the dreamup and load on your dreambox once fully loaded exit the loader and turn your dreambox off and on again at the rear switch now the image will boot and you can the configure the boxLast edited by benny/9; 26 September, 2012, 20:31.Please Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish, -
800 HD se clone xxxSTOPxxx
I was messing around with my Dreambox 800 HD se clone and it?s asked several times before do I want to upgrade firmware. This time I clicked on yes, how stupid now it?s frozen up with message saying :-
SIM 2
(my box IP address no)
xxxSTOPxxx
After reading up on it I believe I need to re-flash it with a sim210 file.
Can someone point me where to get said file from. Do I then flash it with the web browser Firmware upgrader page
The one that comes up when I type in my IP address for the Dreambox.
Will it do the trick and get it back working again
not frozen
SIM 2
xxxSTOPxxx
I?ts not frozen. It is in HTTP boot mode and waiting for you to start a browser on a PC on the network, type the ip address in the adress-bar of this browser and upload the firmware you want to flash.
(I wish I was that far with my frozen box :-)
You can download an image of your choice from the web. Look for images for clones, preferably from your sim card supplier. or you risk to really freeze it.
Dream multimedia built some nice traps in emigma2 and the bootloader to permanently turn off non-official boxes that trie to run them.
And probably (but I can?t check that now) you can just opt-out and reboot to normal from the webpage in your browser.Comment
