dm800se multibutton problem
  • mike d
    • Sep 2009
    • 148
    Hi all I have dm800se clone 82 210 sim using 4direk image. My question is i downloaded multibutton plugin from the Tpanel installed it every thing works fine. My problem is that i can't i had some menus that i won't to asign to the buttons its not in the quick button list file manager and 4direk menu. Is there away of doing this or is there another program can do this?
  • mark015
    • 254
    if your wanting to add .do this go to your plugins/multi quickbutton. press ok either on red, red long, green, green long yellow.yellow long.blue,blue long.after youve pressed ok on watever button u choose you should get the option to add...
    • mike d
      • Sep 2009
      • 148
      yes i know when you add it is limited is there a way so that you can add file folder and others?
