Using two receiver's in the one room
  • garry1312
    • Oct 2010
    • 2178
    I want to use my 800SE and 800 Pro in the same room and same location (TV unit).
    This will be a sort of solution to a twin tuner.
    The problem is if you use the remote it will effect both receivers. I remember a while back I seen a plugin that would stop this from happening.
    So do any of use know were I can find this plugin? Or know of another solution to this problem?
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
  • davvo
    • Apr 2009
    • 666
    DB Switch
    If you have two dreambox receivers in the same room you can use this to assign a key to each receiver so that the same remote doesn't operator both receivers at the same time.
    • garry1312
      • Oct 2010
      • 2178
      Thank you Davvo will give this a try
      • garry1312
        • Oct 2010
        • 2178
        oops sorry clicked on that and it downloads it mate where do I put it and do I put it in both receivers?
        • davvo
          • Apr 2009
          • 666
          download the one below unzip and do this
          - copy the 2 files (db_switch_1.*) to "/var/tuxbox/plugins" (in Box1)
          - copy the 2 files (db_switch_2.*) to "/var/tuxbox/plugins" (in Box2)
          - copy the file (dbswitch) to "/var/tuxbox/plugins"
          chmod 755
          • garry1312
            • Oct 2010
            • 2178
            Thanks mate so how does this work is there then a plugin to assign buttons to each receiver?
            • davvo
              • Apr 2009
              • 666
              not sure as i never had to use it
              have a play with it
              and see if you can get it working
              • garry1312
                • Oct 2010
                • 2178
                Cool will do and will post back on how it functions
                • davvo
                  • Apr 2009
                  • 666
                  go to the plugin menu and select dbswitch and follow the onscreen options
                  you can then control the two dreamboxes with one remote
                  to switch between boxes you have to enter a pass which you setup onscreen
                  the plugin was originally made for dm500
                  iv tried this on a dm800 and its not showing up
                  so this is a non runner
                  there is no other dbswitch plugin for dm800/e2 that i know of
                  unless someone else pipes in and says otherwise
                  • IAmATeaf
                    • 591
                    No idea if the plugin works but on an 800 the plugins folder is /usr/lib/enigma2/python/Plugins/Extensions
                    • davvo
                      • Apr 2009
                      • 666
                      yeah i know that
                      it dont work on a dm800
                      there is a plugin called MultiRC for e2 images
                      it doz the same as db switch
                      • garry1312
                        • Oct 2010
                        • 2178
                        Think I am just going to leave it to be honest get saving for the Ultimo if it ever shows face
                        • lombard
                          • Aug 2008
                          • 793
                          im hoping for dual tuner s2 for dm800se , or Vu Duo clones
                          • garry1312
                            • Oct 2010
                            • 2178
                            Not interested in the Vu Duo clone for a start I dont have much hope in it and second the price on it is not that great.
                            If there was a twin tuner for the the se clone released I would go for it but still want the Vu+ Ultimo come on it justs screams at you 'you have to have me' and if reports are right you could have 6 sat feeds going in to it or a twin tuner, terristrial, and cable...... I would go with 3 twin tuners
                            • skronk
                              • 188
                              And would you invent the 72 hour day so you would have time to watch everything you would record from 6 feeds ??????????????
