deleting barry allen
  • porter1
    • 559
    using new enigma 2 image,dont need barry allen ,wheres the option to remove it,make some freespace,
  • davvo
    • Apr 2009
    • 666
    by telnet command
    cd /
    ipkg remove enigma2-plugin-extensions-barryallen
    then delete every thing for barry allen on hdd/usb
    • porter1
      • 559
      thanks for that
      • 00360362878
        • Mar 2010
        • 488
        You can also use TSpanel mate
        • porter1
          • 559
          that will be easier save connecting cable,looked in there though and never came across it
          • 00360362878
            • Mar 2010
            • 488
            uninstaller in tspanel
            • porter1
              • 559
              its not in any list on there,but shows on boot option
              • 00360362878
                • Mar 2010
                • 488
                which version you got
                • porter1
                  • 559
                  ill look again soon,other half watching her corrie what i recorded
                  • 00360362878
                    • Mar 2010
                    • 488
                    no worries. Latest is 4.1 open tspanel gointo remove plugins choose barry allen, remove then reboot.
                    • porter1
                      • 559
                      its not showing up in there,says theres only 1.59 mb left of space see
                      • davvo
                        • Apr 2009
                        • 666
                        have you got a hdd or usb
                        look in both for a folder called barryallen
                        if so then thats where it is
                        • porter1
                          • 559
                          ye got it through dcc and deleted it,need to make space on flash memory,havent added much and its nearly full up,which causes green screen then it will keep looping and not boot,which i then have to reflash
                          • davvo
                            • Apr 2009
                            • 666
                            did you record to your image/flash instead of hdd
                            • porter1
                              • 559
                              no everything on drive apart from add ons that come on the image,you tube etc
