usb stick
  • umivik00
    • Oct 2011
    usb stick
    I can stick a USB recording a dreambox800hd
    if so how do I exactly do.
  • smokin
    • 255
    Yes you can do this...
    Format the stick
    Go to media, see if you have folder named usb
    If not, make new folder usb, attribute 755, then mount your point to usb, reboot , that should do it..
    Mount from blue panel, device manager, this is how you can mount your usb device
    Technomate-Dreambox-Spiderbox
    • umivik00
      • Oct 2011
      can you explain me is precisely what I should do. I have dreambox 800hd with nabolisat black hole. How should I usb folder in places he recognized or usb stick but then,. where and on what clicks thanks.
      • angeltu
        • Dec 2011
        what os'
        the instructions given above are for linux OS. what operative system do you have on your pc?
        • smokin
          • 255
          format the usb on your PC
          insert usb in dream
          go to menu, select media
          check for usb, if detected, this means its been located and fine to use
          mount from blue panel, ( means press blue button on remote) or device manager, which I recall Nabilosat uses..follow steps given to you
          at point of recording select the place you want- like usb.
          works in Windows..
