Yea it's dm800 clone... If I try this tutorial there's no way I can f**c or brick is it called up ?
Scared to go into settings as everything else is perfect just setanta channels & epg needs downloading all time.
Ta m8
pretty easy if you follow the tutorial, if you get stuck post back here
So andy thx m8, I can do this with laptop & no need for lead ?
I have channels on bouquet, does it stil need updating is it something u do every so often ?
I don't even understand the bouquet to be honest, is it like a favourite channel list ?
Rob
Rob
a bouquet is basically a way to organize your channels to your liking as by default a scan will list all found channels in alphanumerical order. Yes you will need to rescan or update your bouquet every single time sky so much as decide to change a PID or move a channel to a new frequency, as only official sky boxes have the necessary code to auto update.
providing both the receiver and the pc / laptop are on the same network you need not use a lead, you can do it all via wifi but the box will need to be hooked up to your network with a network cable or wifi stick etc.
I'm getting it now, there both on same network modem, so if I follow the tut above I should get there ok, there's no chance of messing the box up ?
So I need the ip address ? Can I get this from box info ?
Ta rubberduck
