Fitting a disc drive
  • robbeno
    • Feb 2010
    • 389
    How easy is it to connect a hard drive to a dm800 ? I've got a spare laptop not being used, how easy or hard will this task be, removing out from laptop & installed, how much would it cost roughly to be installed
    Any advise would be appreciated
    Thx
  • cunny
    • 4915
    Its probably just as hard as getting it out the laptop. Its 4 case screw to get top of case. 2 screws for drive casing. Fit wires. Replace screws
      Anythings easy if you know how. It's easy enough to do if you have a bit of pc knowledge.
      • robbeno
        • Feb 2010
        • 389
        Not much pc knowledge to be honest, never opened a laptop before, I didn't flash or do anything on my dm800 it was all sorted when i bought, Im new to the box, how much would it cost about for this to be done ?
        Cheers guys
        • cunny
          • 4915
          Have a look on YouTube for a tutorial. Its 6 screws in the dm and prob 2 in laptop
          • robbeno
            • Feb 2010
            • 389
            Yeaaa will do, but is it just take out & put in, can't seeing it as easy as tha
            I'll av a gozz on utube
            Ta m8
            • abr
              • Aug 2010
              • 108
              you need a sata h/d to fit into the dm800
              make sure the one in the laptop is sata (some are ide in older laptops)
              taking the h/d out of the laptop and installing in the dm800
              is not to difficult the dm manual will show how its done
              you will need to format and mount the the disk in the dm800
              • robbeno
                • Feb 2010
                • 389
                My pc is a old version about 6 yrs old, so il just buy of eBay
                Ta bud
                • robbeno
                  • Feb 2010
                  • 389
                  Ordered a disc drive of eBay
                  2.5 sata 250gb , I've got leads tha came with my box are these what I need to insert it ? And after connected up, do I have to download anything ?
                  Or is it just work straight off ?
                  Advise would be appreciated pls guys
                  Rob
                  • skronk
                    • 188
                    Rob
                    No leads required. It slides into socket on box.
                    My drive (Samsung) did not need formatted at all. Worked straight away, though there is an option in the menu to format/initialize HDD.
                    It's pretty straightforward to fit.
                    • abr
                      • Aug 2010
                      • 108
                      Rob
                      download the manuall for dm800
                      all will be explained in that.
                      page 42 onwards
                      • robbeno
                        • Feb 2010
                        • 389
                        Thanks guys
                        Just looking at the hard drive I've ordered then I seen a diff kind
                        Wich one if these is the correct 1
                        • andy211081
                          • 575
                          2.5 sata is fine...and if its a dm800hd you need the leads but if its an se then it is slots straight in.
                          [ame=http://www.youtube.com/watch?v=FwGz84eL2LU&list=FLklKK0mcIO4UrZU5QqUHk4A& index=11&feature=plpp_video]Smontare Dreambox dm800hd e montare la ventolina - YouTube[/ame] shows how to open the dreambox.
                          i have tried to uploaded the manuaal to the dm800hd and its on page 43..explains how to install the hard drive, but it exceeds the file size on here...so will add to the downloads section now for you
                          Hope this helps you
                          Andy
                          Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
                          • andy211081
                            • 575
                            as promised http://www.digital-kaos.co.uk/forums...d-manual-1919/ page 43 is what you want
                            • RabbitRunner
                              • Nov 2011
                              • 13
                              New dm800HD se Clone hard drive installation
                              I got a new hard drive for installation in a new sunray clone, it plugs into its caddy, but I can't seem to find anywhere i'm meant to connect the power to it from the dm800hd SE for the sata drive.
                              Any advice guys?
                              Thanks in advance.
                              Yours kindly,
                              RR
