Im confused, what image can i use?
  • yogzy
    • Jun 2011
    • 7
    Hi currently have dm800hd clone, dream elite blackhole( italian for some reason ? ) sim 2.01 and bl76c( from xx/6/2010 i believe.
    what newer images can i install as ive seen bl78 , bl82 and now bl84 images?
    i dont obviously want to put the wrong image on but im a bit stuck.
    reason for upgrading image is cause my EPG doesnt always work porperly ( rytec ) and i have no download server to download any new ones. Plus new is always better
    Please help
  • IAmATeaf
    • 591
    You can use any image that's intended for SIM 2.01, this is the important thing to check and double check.
    The ssl you can also update but for the latest 84b and if coming from a lower version you might need to flash the ssl first before flashing the image.
    • yogzy
      • Jun 2011
      • 7
      ok thanks
      so lets get the right
      i download a pre patched image 201 bl84
      use IE option to install it on my DM800 and thats it?
      or do i then have to flash the bl84 file aswell?
      thats where im getting confused
      do i need to send the bl84 file over after i have flashed the dm with a patched image?
      • Rodbouy
        • Jul 2010
        • 1320
        Try this image mate,
        BlackHole-1-6-6-dm800hd-ramiMAHER-v3 final #ssl84a
        It has the ssl84a built in.
        Just flash by browser and jobs a good un.
        Cracking image
        This is for the Dm800 sim 2.01 NOT se
        • 00360362878
          • Mar 2010
          • 488
          Originally posted by yogzy
          ok thanks
          Flash ssl84 first mate, then the image.
          • yogzy
            • Jun 2011
            • 7
            the above 2 posts have just said opposite things.
            if the image is already patched then just flash it to the dm800 and thats all right?
            • 00360362878
              • Mar 2010
              • 488
              Try the image 1st if you like, but it will be looking for the ssl84, so you will need to load the ssl84 nfi file.
              • yogzy
                • Jun 2011
                • 7
                Cracking image
                your suggested image worked a treat thanks
                • 00360362878
                  • Mar 2010
                  • 488
                  Nice1, give rodbouy's thanks button a bash mate.
                  • robbeno
                    • Feb 2010
                    • 389
                    I'm in same boat image I'm using dreamelite blackhole also in italian, epg comes, goes I'm forever downloading it via rytec, I need to change image also, is there a link on how to go about this, as i've only had boxs a couple of weeks, not got a jar ov to be honest, do I need to download anything on my laptop ?
                    As I've tried downloading dreamedit to upgrade my bouquets & can't even open it out my downloads. Stuck!
                    Any links guys would be appreciated pls
                    Rob
                    • Rodbouy
                      • Jul 2010
                      • 1320
                      What box do you have?
                      Also, if its a 800 with sim 2.01 then just flash the img above.
                      To do this turn box of and have it connected to your router.
                      Now press and hold the front ver on button and then put power on whilst holding down button still.
                      Now watch the screen and when it says stop let go and take note of ip.
                      Enter ip to ie then firmware upgrade and flash the image
                      • robbeno
                        • Feb 2010
                        • 389
                        Exactly it bud, I'm a dum dum
                        Don't no wot a ver is n were it is ha
                        Do I need toconnect laptop to router ? Or box
                        Is dm800 clone
                        Is there a link for that image above step by step like from scratch, I'm a total noob m8
                        • Rodbouy
                          • Jul 2010
                          • 1320
                          that is pretty much step by step mate.
                          on the front of the box the oled screen when you do what i said above it will tell if you its sim 2.01 or not
                          Yes you need the box connected to the router, either by wifi or wired.
                          Your box needs connected to router, this will enable them to talk
                          You can do it direct but the easiest way is the above.
                          Just try it mate
                          • hacka247
                            • Dec 2011
                            • 37
                            cant see ip to get to flash image
                            trying to install this image on DB800HD but when i plug DB out and plub it back in with the power button depressed eventually i see stop but ip does not show i just see DHCTP.any help will be appreciated
                            • smoggie
                              • 863
                              how have you got the ethernet lead connected to dm??
