dm800 clone tuner
  • stew86
    • Nov 2010
    • 236
    dm800 clone tuner
    hello i have A DM800 HD clone i have bought a new tuner for the box but the box is saying tuner A empty nothing i have flashed the box with a number of different images and its still not working i have read alot of different posts but cant get a answer any help from you guys would be a big help thanks
  • benny/9
    • 1964
    have you tried clearing the box and then
    loading a new image with a patched dreamup panel
    Please Read Carefully!
    • stew86
      • Nov 2010
      • 236
      sorry for the later reply been stuck in work how do i clear the box and what is a patched dreamup panel i am new to dreambox always was on the cable side of things
      • benny/9
        • 1964
        first upload a image for your box and take it from the folder and
        put it on your desktop ready to load next you run and open the
        patched dreamup loader panel and connect the dm800 to the computer
        with both a null modem cable and the cat5 cable to your router
        then you unplug the box and open the dreamup loader you need
        your computer ip and the dm800 ip entered on the loader use the last one
        you used when flashing it also make sure theres a tick in use network box
        on the dreamup, then you click connect on the panel it will say connected
        turn the box on , now plug the cable back in and you will see the loader
        uploading from your dreambox, once done>ok. it should allow you to click the flash button on the panel and a window will open where you find the image
        that you left click on and then click open on the window this will now load
        the image on your box once fully loaded>ok exit the dreamup loader and got
        to the dm800 and unplug it wait for a min or so and plug back in and the box
        will boot up and should be back in working order,
        if the above does'nt work or any problems post back everyone
        will try and help you, it can take more than one go to get it to work
        • 00360362878
          • Mar 2010
          • 488
          Stew.
          Did you configure the tuner, and load settings or scan sats. I am assuming you have changed from cable to sat.
          • stew86
            • Nov 2010
            • 236
            hello i had a sat tuner in the box and i was watching football one night and it just turn to a black screen checked different channels included free to air all the same black screen i tryed my friends box in my house it was working fine with my NLine and feed in so reading arounding i thought it much be the tuner so bought a new tuner
            • stew86
              • Nov 2010
              • 236
              newnigma2-dm800-v3-3-1ramiMAHER
              thanks benny/9 for the help tryed everything you said but the box is still saying tuner a empty nothing do you no a good image i come try i have use
              BlackHole-1-6-6-dm800hd-ramiMAHER-v3-
              sim201-SS82-de-133dv3PHOENIX2-dm800-13052011
              thanks for all your help
              • 00360362878
                • Mar 2010
                • 488
                Hi Stew
                So when you go into tuner configuration, is there nothing in there?
                • stew86
                  • Nov 2010
                  • 236
                  no nothing it says tuner a empty nothing
                  • 00360362878
                    • Mar 2010
                    • 488
                    Thats very odd mate, your obviously not new to the box, so I am sure you have tried alsorts. The only thing I can think of is remove the tuner, clean up the contacts and reseat it.
                    Not much help mate but best of luck.
                    • stew86
                      • Nov 2010
                      • 236
                      hello does anyone no how i check to see if the drivers are installed and up to date thanks DK for all your help
                      • potrobber
                        • Mar 2010
                        • 493
                        hi i had the same fault with a clone 800 when i put a different image on reflash it with a new image to suit your bootloader and make sure when in the setup wizard to setup your tuner to your sat needs
                        • stew86
                          • Nov 2010
                          • 236
                          i have reflash the box with a number of images and i cant set the tuner to the sat i want
                          • benny/9
                            • 1964
                            look in the box menu and see if the tuner is set
                            menu>setup>ok>system>ok>customise>ok
                            and scroll down the list to near the end od the list
                            and make sure the alternative services tuner priority
                            is set as DVB-S/-C/-T if not use the left/right buttons
                            on the remote either side of ok to change the setting
                            • blueflash234
                              • Mar 2009
                              • 904
                              take the tuner out and clean the contacts and make sure its pushed in fully when you refit it
