Ip address
  • spurx1
    • Dec 2011
    • 16
    Ip address
    Have had a dm 800 hd clone for about a week now, have installed dcc, everything works ok, however the ip address of the box keeps changing everyday it seems. When i open dcc i have to search for the dm800 each time and the last digit of the ip address has changed. I have a netgear router. This is a bit of a pain as i use dream stream and i have to keep re installing it each day. Any ideas as to why the ip keeps changing?
  • 00360362878
    • Mar 2010
    • 488
    Do you switch your router off every night.
      Setup\ system\ network\ Adapter settings\ set use DHCP to NO
      • spurx1
        • Dec 2011
        • 16
        Yes i do switch the router off...guess i should be keeping it on then?
          If you turn DHCP off you can turn the router off and the ip will stay the same.
          • spurx1
            • Dec 2011
            • 16
            Thank you for that...will change that setting.
