Tuner Failed
  • lofty69
    • Jan 2012
    Tuner Failed
    Hi All,
    Im new to the dreambox scene so I appoligise in advance, my dreambox 800 dvr clone, was working fine but when i changed my room around and added a exstension cable to it, so i could have my box over the other side of the room certain channels have stopped working. I have changed the tuner to a M rev, i have also added a amp, i have also tryied manually scanning but BBc1,2 channel 4 channel 5 and certain other channels just say tuner failed?? Please if anyone has come across this problem please can you help me.
  • nathan2007
    • Jun 2011
    • 448
    have u updated your boquets on the dreambox? ( use sgtflipflops on here)
    have u checked the connections are all tight and nothing has moved?
    alos silly question is the amp connected the right way?
    just a few suggestions .................
    • lofty69
      • Jan 2012
      Hi Nathan2007,
      Thanks for your reply, yes ive checked the amp is the right way but i havent updated so i will have ago in a sec with flipflop
      • smoggie
        • 863
        you shouldnt need the amp with the m tuner. The thing you have added is the extension cable which is most likely your problem. put it back where it was and see if its okay, if ok investigate your extension lead.
        • lofty69
          • Jan 2012
          Yeah its more then likely my change over, what is strange is that when i go into dreamedit it does say that 6 channels are currupt maybe it has somthing to do with that, also i updated with sgtflipflop but the channels still dont work.
          Thanks again for your help on this guys
