d800 hd s replaced tuner
  • raf10
    i have a dreambox d800hd and i have flashed it with various images but when i come to configure the turner it says empty and i cant select any options. i thought it may be the tuner so i purchased a new rev m tuner and replaced it but now the box jus keeps rebooting and wont load any images.
  • milkcup86
    • Feb 2011
    • 62
    I've got the same problem just keeps on saying empty. I've tried new images and reseating the tuned but no luck though.
    • benny/9
      • 1964
      use dreamup with the null modem and cat5 cables connected
      and also load the image after the box uploads to the dreamup
      and then when it goes into http mode. if your boxes are clones
      use a patched dreamup loader
      Please Read Carefully!
      • milkcup86
        • Feb 2011
        • 62
        Flashed it a couple of times with a patched dreamup with no success. Then tried the original dreamup and got no ca found error. Flashed an old image with the patched dreamup and success it let me set up the tuner in the wizard.
        • raf10
          i flashed it 2 but when it came to scan it only found 34 channels and then when i went to view the channels it came up with an error tuner failed what image did u use? and wat bootloader is ur box? mine is bootloader 70 any chance of posting me the link of where u got ur image from. thanks
