Help needed - direct recording to NAS
  • revy32
    • Sep 2011
    • 42
    Hi,
    Is there anyone who could give me a step by step guide for setting up my NAS for direct recording from my DM800.
    I have set up the NAS in as much as I can go into "media player" on the DM and watch films from it but I can't seem to get it to record.
    I have read Devilfish's post but that was originally 18.05.2008 and the CONFIG option isn't on my DM webpage.
    I am using Enigma2 Phoenix image and wondered if anyone could help me with an "idiots guide"
    Thanks in advance
  • whatsup
    • Dec 2011
    • 11
    Hi M8
    Depends on image on mine I went into:
    Menu/setup/system/Recording paths
    select: timer recording path
    press menu select switch filelist
    press menu add bookmark
    You will need a directory called movie and you should then be able to add a bookmark to record.
    In my case my network mount was already pointed at movie but I had to create a sub directory of movie before it would show up.
    Only fumbled my way throught this last night so cant give you a step by step but hope this help.
    Cheers Whatsup
    • southpaw
      • 2233
      There is an option in "network " tab called " network browser ", use this to scan for your nas drive, enter user/pass and select "use as hard drive replacement "
      Should create its own movie folder an away you go!
      • revy32
        • Sep 2011
        • 42
        Thanks guys, I'll give all that a go later.
        As I mentioned I think I'm there or there about but as you know one / or . in the wrong place and things don't work.
        I'll let you know how I get on.
