dm800 - motorised dish stuck on 1 satellite
  • gavone1
    • Feb 2011
    hi
    I have a motorised dish that will only go to 19.2e and I cant get it to move from there. I have had dm800 before and it worked fine with the motor. now im using my new dm800 (dreamboxuk image), hooked up to the same motor it will only go to 19.2e. I have the tuner config set to simple - my long and lat set up and postioner is usals. any ideas why it wont move to another satellite? it sometimes loses power on the motor as well and i have to restart the box to get power back. i have changed the tuner config as it was set to only go to a single satellite when I had it.
    anything else you need to know let me know.
    any help would be appreciated.
    gav
  • portbhoy
    • 717
    I had this the other day and I found a reflash solved mine. I've also had it before and had to reset the motor or reseat the tuner. I would start with reseating the tuner if that doesn't work try a reflash which is probably the easiest thing to do.
    • gavone1
      • Feb 2011
      how would i reset the tuner? im sure its something simple ive missed
      • simongr
        • Feb 2010
        dish stuck on 1 sat
        My satellite dish is stuck on Astra 28degrees...I have nemesis 2.5 image ....please can anyone help
        • smirnoff_rules
          • 8603
          go into menu and tuner settings and is in simple or advanced ?
          • mike d
            • Sep 2009
            • 148
            I have the same problem some times it moves and some time it dont. I have tryed about 5 images and get the same problem. The motor is new and my older one too, Its fine on the tm9100 super but not with this box. any ideas?
