Getting this box tomorrow, hopefully i don't get these freezing issues, i know it comes flashed and with an M tuner. So which soft cam is better, cccam or mgcamd on the pro version?
I use to think it was my ISP.. but.. I'm a curious guy.. I went to investigate...
Ring Wires
My internet used to alwaysdrop out, sync at slower speeds and even when it did work I used to get glitching every few minutes. (I thought it was the ISP, or a server issue), tried everything (replacing broadband filters, tried another router, different sockets, everything).
I opened my telephone socket, and found that I had something called the `ring wires` connected. These `ring wires` are usually not needed nowadays and only impair the signal quality of you broadband (they pick up unwanted electrical & radio noise), Mine were connected!.. I pulled these little fu*kers out (only leave wires 2 & 5 connected, they are numbered so just read it), and BAM!! My signal strength shot up. (This temporarily made my internet connection really bad!)
BUT...
After... I rang my ISP, and asked them to reset my settings at the telephone exchange (tell them you pulled the ring wires out!), My Signal to Noise Ratio for my broadband went to around 20db[it should be around 6db], This is because we pulled out the `ring wires`. This is good!!..
After the ISP reset my settings (at the telephone exchange), I waited a day (be patient, it can take up to 3), and now I have a solid, stable, superfast Internet connection.
It solved all my glitching problems, (which I thought was my ISP, or faulty router, or broadband filters, or all this other crap).
Now.. my internet & dreambox(s) (I have 2) around my house work glitch free....ALL THE TIME.
- My internet speed increased, (8mb to 12mb!)
- Now never drops out, NEVER.
- Its even faster then before, (ping rates saw a good increase +10ms). - And has been my best friend since....
I learned alot doing this! ahhhh..memories!!
- Thanks to those who deserve them, and none to those who don't...
- DM 800 HD - Clone | DM 800 HD SE - Clone | Openbox S11
- weedman
as i said in post b4 mine turned out to be my c line. like people have said in other posts its either their server or your internet. if there was any problem with the box you would get the problem on all channels. inc fta
i have the same box as you with same tuner.
try asking some people for test lines and try them see if it works any better.
also if your using your laptop or computer that could affect the tv more so if you use something like bit torrent, using alot of upload and download on your internet.
Turn dreambox off from the wall then wait 20 or 30 seconds then hold the button on front of dreambox and power on , your ip address should come up on the front LCD screen of dreambox.
I have a 800pro rev m an 800se clones, both do HD perfectly without glitch, an that's on a 40m cable length, older 800 with rev j , k an l were awful compared to the latest tuners
