install bl 82 thn 84
  • D1SHABBA
    • 68
    prob been asked a million times but iv searched and searched. i got a dreambox 800hd, dreamelite blackhole, sim 201, bootloader 76,
    i have two questions:
    How do i install the bootloader 82
    thn move it onto 84
    by the way dreamup not working on my pc so im stuck in that sence...
  • D1SHABBA
    • 68
    someone please help
    • mdt
      • 3034
      Originally posted by D1SHABBA
      someone please help
      you need to use IE and get yourself a ip addy from your box by switching the power off at the socket then switch back on with the standby button pressed untill it says stop on the dm800 screen. type in the ip addy into IE then on the dreambox ip update page go to firmware upgrade and then load ssl 84 like you would a image it takes 1 second to do. if you cant be bothered with the bootloader just find a patched image for your sim version(sim2 or ferrari) with ssl84 built in and follow the procedure again to flash your box... you shouldnt need dream-up on your dm800 clone unless there is a major problem.. eg no ca found, regards mdt
