recording on dm800se
  • challah
    • 242
    hi to all
    just need an answer to a few questions
    im thinking of getting a dm800se and need to know what i need to do to record
    first do i need to install a 2.5 hard drive
    second do i need to get a twin tuner
    third how many channels can i record at the same time
    thanks in advance
  • challah
    • 242
    sorry to add what size hard drive and does type matter
    cheers
    • alom5
      • 1648
      if you get the 800se, you will only be able to record the channel you are viewing (tho sometimes you can watch a different channel if the other channel is on the same transponder - very rarely happens)
      if you want to watch 1 channel and record another - you will need a twin tuner receiver....there is now a vu + duo clone out which will allow you to do so.
      the size of the drive is upto you, if you intend on doing a lot of recording...in HD as well something over 250gb will suffice.
      • challah
        • 242
        thanks for the reply, is there any other boxes that you can record and watch different channels.
        cheers
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          you'll need twin tuner..
          starting at around 180 for the qbox mini, 200ish for vu duo clone.. up to 300 odd for original vu duo or clarke tech
          • challah
            • 242
            thanks for the replies i have learned a lot tonight.
            cheers
