HELP!!!
  • trotsky75
    • Feb 2012
    • 25
    #16
    Thanks Southpaw.
    Any pointers on how to install tspanel on Openpli?
    • trotsky75
      • Feb 2012
      • 25
      #17
      Got it.
      FTP'd ipk file to root and installed local extension - sorted.
      • trotsky75
        • Feb 2012
        • 25
        #18
        Spoke too soon about the wifi working!!
        LAN adapter - OK
        Wireless network - OK
        DHCP - OK
        All ok until I unplug my ethernet cable and then IP address is un-confirmed and no internet connection!!!
        Tried turring DHCP off and assigning IP manually but no joy.
        I have hunted through the settings on my router but nothing seems to work.
        ANy ideas?
        • mugello
          • 63
          #19
          Hi trotsky75,when you turn DHCP off,and inputting IP manually are you rebooting box in order to save settings?
          Cheers
          • southpaw
            • 2233
            #20
            Presume you already tried above re reboot? , Only thing I can suggest is Google the fault it gives you, somebody else may have had same issue, Google it an put the exact fault it displays in quote marks " " , with dm800se out of the quotes, sorry mate, not much help I know, but I can't suggest anything else as I avoid wireless on all my devices, bar phones obviously,
            Good luck
            • trotsky75
              • Feb 2012
              • 25
              #21
              Thanks guys - seem to be making progress but still not quite working.
              Have found some sim2 wifi drivers in the tspanel which seem to help once I have assigned ip address manually (dhcp off).
              I now get green ticks for everything:
              Lan -OK
              WIFI - OK
              IP - OK
              Nameserver - OK
              But when I try to connect to interenet - eg through tspanel - it tells me there is no internet connection.
              Have re-booted box and router many times now.
              Still searching google......
