Help to flash
  • Bann32
    • Oct 2011
    • 518
    Help to flash
    I have a R6 network cable (no DHCP Server), it seems my DM800SE doesnt have a comm/rs232 port am I able to flash/update my DM800 or do I need a different cable? or setting up a DHCP Server is a must?
    EDIT: Its ok, I need to get an a to b usb cable, I think
  • Bann32
    • Oct 2011
    • 518
    Ok how do I tell which DM800SE, I know its a sim2 but thats all
    • southpaw
      • 2233
      None of them have a comms port mate, you need to attach it to your router then it will be networked with its own IP address, you then flash fw thru a web browser,
      Look in the sticky section for "flashing dm800 " , its same method for SE,
      If you have sim2, then the fw /image must be sim2 compatable
      • southpaw
        • 2233
        As in your edit , you can use the mini USB connection, but most peeps use the web interface method I described above
        • Bann32
          • Oct 2011
          • 518
          Thanks for the reply, It just seems there are several sim2 with different numbers on the end.
          Is there one that someone would care to recommend
          • toonarmy9752
            • Feb 2012
            is the numbering on the end of the sim2 files a version number and does the the higher number mean a later version?
            • Bann32
              • Oct 2011
              • 518
              It decides which bootloader you use unless the image comes with it -
              ssl82 both enigma2 and drivers must be patched
              ssl84 allows you to use original drivers
              in the end I used - BACKUP DM800se SIM210 SSL84b - Patched by riyaad
              As suggested at the end of this thread:
              now I just need to find out, which plugins are best to use with this image
