Struggling
  • Hoppo
    • 64
    Struggling
    Dreambox 800 HD
    Hi I?m struggling to add more satellites and a muti bouquet. Received my box a few days ago, all working with 28.2e bouquet. Add my c lines (There?s another question later) all ok. Added 14 more satellites which looked ok and did a full scan. When the scan had finished added a muti bouquet bybSGTFlipFlop and that?s when it all goes wrong, place on a channel on 39 E and it goes over to near 0.8w. Ask it for to go to 0.8w and it goes over to the east. Ask it to go to 28.2 and it goes there showing SNR 87% then SID not found in PAT or tuner fail. I can send it to 13e and it works Ok. Other satellites it doesn?t find. Satellites set to Diseqc 1.2
    Sometimes I may get with Snr showing a good signal but no picture
    Thinking of getting rid of all channels and starting again if anyone can point me in the right direction
  • dctyper
    • 2539
    you need to dl the settings too
    dc
    • Hoppo
      • 64
      Thanks for the reply but i still don't understand can you explain some more thanks
      • Fergal
        • 1007
        Try changing your tuner configuration reception settings to
        configuration mode = simple
        mode = positioner
        longitude = whatever yours is if it has a - put in east
        latitude = whatever yours is
        then try switching sats
        • Hoppo
          • 64
          Thanks for the replys dont know what I have done but things seem to be going OK now must be some thing simple. Off to try and input more satellits Thanks again
          • Hoppo
            • 64
            Think I have found what I was doing wrong saving stored potion in Tuner configuration with different numbers but saving as 1 all the time in Positioner setup now matching them together is working LOL
            Last edited by Hoppo; 3 March, 2012, 13:10. Reason: made words bigger to be able to see them
