dm800se network config
  • jondalor
    • 37
    hi guys, i,ve just received a dm800se, it came preloaded with open pli image, i've CCcam 2.1.3 now loaded, my problem is that i can't find which port the box is using, it doesn't seem to be in Setup-System-Network, so where is it? also i can't find where i can switch between cams.
    any help please
  • southpaw
    • 2233
    Try. Blue button /softcam setup for cam switching,
    Not sure what ya mean about ports mate,??? Why do you need any port info
    • jondalor
      • 37
      if, for example, this box was to be used as server?
      • alom5
        • 1648
        then you need to forward a port to the box (all done on your router) and put that port number in your cccam.cfg file so it knows what port to listen
        • jondalor
          • 37
          where in cccam do i do this? i am looking to change server and last time i set port 1xxxx on the box, the router is already done, and working on a different box (server)
          • alom5
            • 1648
            it goes under you sealions
            server listen port : ######
            don't ask anymore about this on this forum as it's not allowed.
            you can google cccam and you will find help.
            • jondalor
              • 37
              understood
