Neither a "services" nor a "lamedb" file was found in directory on the Dreambox.
  • khalsa techi
    • Feb 2012
    • 13
    Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/
    I'm trying to setup DreamboxEdit and when I select the option to "Recive Files from the Dreambox-I get the above message, can someone help me with this, I've been trying to setup my DM500S box, I installed the Neutrino 14.4 Image, The image is great but there are a large number of channels that do not work, just display a blank screen, I greatly appreciate your help, I'm loosing the will to carry on with setting this up.
    Last edited by khalsa techi; 4 March, 2012, 13:55. Reason: Did not finish my question
  • Rodbouy
    • Jul 2010
    • 1320
    Wrong section mate and goto dreambox edit options and change path from enigma2 to satellite then save
    • khalsa techi
      • Feb 2012
      • 13
      The DreamboxEdit Option screen shows the following:
      File paths on the Dreambox: (this is the current settings)
      Services & Bouquets files> /etc/enigma2/
      User bouquet files> /etc/enigma2/
      Satellite.xml file> /etc/tuxbox/
      Path for Picons on dreambox> /media/usb/picons
      Where am I going wrong, which path should I change, sorry for being in the wrong section, but thanks a million for your help.
      • khalsa techi
        • Feb 2012
        • 13
        I changed the first 2 paths from /etc/enigma2 to /etc/satellite and then saved it, but then got the same error.
        • Rodbouy
          • Jul 2010
          • 1320
          what bouquet list you adding?
          • khalsa techi
            • Feb 2012
            • 13
            Where do I find the bouquet and how do I add this, I'm sorry but this is all new to me.
            • khalsa techi
              • Feb 2012
              • 13
              DreamboxEdit
              I'v removed DreamboxEdit v5 and have reinstalled this with version 3 - but still get the same error, see below.
              Connecting to 192.168.1.6.
              Connected.
              Dreambox response: Login successful.
              ** Retrieving file list of "/var/tuxbox/config/enigma/" **
              Starting FTP transfer
              Transfer complete
              Transfer complete
              Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox. /var/tuxbox/config/enigma/
              Check the dream path settings on the option panel to point to the correct Dreambox directories and try again.
              Disconnecting.
              Disconnected.
              I Have a D500S box with Nuetrino v14.4 image installed, with DreamboxEdit Version 3.0 on my PC. PLEASE HELP !
              • Rodbouy
                • Jul 2010
                • 1320
                what bouquet list have you loaded in to dreambox edit for your box?
                go get sgt flipflp enigma 1 bouqet
                then extract the folder, load in to dbedit then ftp them to box
                • khalsa techi
                  • Feb 2012
                  • 13
                  Hi thank for the reply, really apprciate it. I have extracted then files, opened the DreamboxEdit, clicked on Open and it placed a number of channels on the left pane when I selected the first option which was "bouquets". I selected the FTP icon-"Send files to Dreambox" but got the following message.
                  Connected.
                  ** Getting directory list /var/tuxbox/config/enigma/* **
                  Transfer complete
                  ** Sending file "/var/tuxbox/config/enigma/services" **
                  Transfer aborted
                  Error sending file "services" to the Dreambox.
                  Disconnecting.
                  Disconnected.
                  • khalsa techi
                    • Feb 2012
                    • 13
                    Hi there,
                    I've managed to FTP to the box, which then required a reboot.
                    I was then able to Recieve files from the Dreambox.
                    I had to change the path in DreamboxEdit to get this working:
                    It was set to /var/tuxbox/config/enigma/ and is now /var/tuxbox/config/zapit/
                    there was no path that had enigma when I checked using DCC.
                    What do I do from hear to get all channels working, as there are a lof of them just showing a blank screen.
                    • southpaw
                      • 2233
                      There is a guide in sgtflipflops settings link above
                      • mahabadi296
                        • Aug 2012
                        i have this problem.
                        Connected.
                        Transfer complete
                        Transfer aborted
                        Disconnecting.
                        Disconnected.
                        • marty45
                          • Jun 2009
                          i have the same problem this is what i get Neither a "services" nor a "lamedb" file was found in directory "%" on the Dreambox
                          what does it mean help please
