Dm800hd Pro (clone) Tuner A (empty)
  • saintbri
    • Sep 2011
    • 6
    Hi
    I have been using my DM800Hd pro clone without any problems then suddenly the picture froze and message of Tuner failed. Since then I have had not Tuner , I have read various threads but cannot find an answer to the problem. I have have tried re flashing image with various inc the correct bootloaders etc but no luck. The tuner is M and I have had the box for about 2 months. I have checked to see if the tuner has become unseated but all appears to be Ok. The internal fan is working Ok. Is it a case of purchasing another tuner and if so when fitted do I need to reflash the image (gemini currently) again.
    Any advice would be appreciated.
  • stew86
    • Nov 2010
    • 236
    hello i had the same problems with the tuner just bought a new one off flebay re-flash image happy days up and running
    • alom5
      • 1648
      if ireflash hasn't worked and t's only been 2 montsh....contact your seller.
      • j1mgg
        • Feb 2011
        • 61
        If you buy a new tuner you wont need to do a reflash but it is probably better to.
        Can you get in to choose a tuner under the sat settings?
        • saintbri
          • Sep 2011
          • 6
          Hi
          Thank you for responses , the box was brought from china so no chance of sending back. cannot choose a tuner under settings I;m afraid tried so may many images with the correct BL made no difference.
          Not sure what else to do.
          • saintbri
            • Sep 2011
            • 6
            Hi
            I was using an Open pli image which had ccam230 included when the problems started (last sat) .
            Can anyone suggest an image with perhaps a lower BL that may be more stable to use again with a ccam incuded etc.
            I really do appreciate the response I have had so far.
            • neegee
              • Feb 2012
              Hi! I have the same problem with my dm800se! The box was working fine for ca. 2 weeks, but after my problems have started. One reboot and i've had the Tuner A empty message, one more reboot tuner was fine...and so on. Now the box detects the tuner once in 100 restarts... My new tuner is on its way to me
              • saintbri
                • Sep 2011
                • 6
                Hi Neegee
                Hope you have better luck then me fitted a new M tuner but it has made no difference I have lost count on the number of images I have trrie with the correct BL.
                It clearly is a fault with these clone boxes
                • neegee
                  • Feb 2012
                  I really hope so Saintbri! How do you flash your images btw? Via Browser or do you use DreamUp? Cause i've noticed that my tuner was detected when i flashed the image via DreamUp at the first time. But now is the tuner completely dead, it doesn't make any difference which way i flash.
                  I've already replaced my power supply unit for a quality one, cause i've read on a different forum that the dodgy PSU caused the empty tuner problem. Maybe you could give it a try as well!
                  • saintbri
                    • Sep 2011
                    • 6
                    Thanks Neegee
                    I have tried 3 PSU for this box also flashed by D up and via i.e.
                    It has made no difference still have the same problem.
                    Thanks for the ideas
                    • ceppa77
                      • Mar 2012
                      • 8
                      Hello!
                      I have the same problem... does anyone has a solution that might not involve buying a new tuner?
                      I have DM800HD pvr and I really don't know what to do as I tried several images and tuner drivers but I still have empty Tuner of error 0x1800f...
                      • Gemaxi
                        • Mar 2012
                        the same kind of problem
                        Hello I bought estar dm800 receiver owners,
                        I have also these receiver and i must tell to administrators that we all have problems with tuners when we install images with new kernels
                        Only old Kernel 2.6.18-7.3 working good on these estar dm800 model
                        all new Kernel 2.6.18-7.4 was with signal problems and also new 3.2 enigma 2 (also with remote problem, remote not work on new enigma 3.2.2)
                        can anyone have the solutions to solve
                        Regards
                        • skanxsta
                          • Aug 2009
                          Originally posted by ceppa77
                          Hello!
                          this worked for me:
                          -go to the field where it says "No Tuner"
                          - press right arrow on remote
                          - keep pressing it and if you are lucky you should then see a sat setup page.
                          - select a sat and LNB and save it.
                          If you got thru those steps,, it should then show your tuner being recognised.
                          Those steps worked for me. Hope they help someone else
                          • neegee
                            • Feb 2012
                            I bought a new tuner from mixeshop.com. I've replaced my old tuner, which wasnt recognized by the box(Tuner empty message). After the first reboot i was very happy, because the new tuner works perfect.
                            • boogie
                              • 26
                              sorry to bring up and old(ish) thread..
                              I have the same no tuner problem.tuner is fine(tested on another box)
                              running patched(estar) pli latest.
                              image is great except for no tuner problem..
                              eardatek site is s**t.no drivers no info as to which drivers it might use
                              tuner has no markings for me to make any pertinent guesses..
                              I have dug this up as there are no other sensible ideas on the interweb and I have searched (hard) for days...
                              could it be something to do with the drivers for the tuner being too 'new'.if so how do I go about getting the relevant files loaded?
                              cheers
                              edit:and is there any way to find out which drivers I need by identifying the tuner model?
                              edit:santibri did you ever resolve problem?
