The dreaded 'Error 01 No CA Found'
  • CoolKen
    • Feb 2012
    • 19
    I wonder if someone can help before i go mad, so many threads discussing this..
    Basically i bricked my 800HD using an original bootloader image, yes stupid i know, only realised after.
    So ive tried various versions of dreamup none of them manage to detect my dreambox on power up, nor am i able to overide the No CA found error on power up holding in power button.
    Im not sure what bootloader to download, although i tried one with the 'enforcer' option and it said 'file to big'
    I was using the usb/serial from maplin with a brand new null modem cable but after reading mixed reviews on the drivers i built my old machine with a single com port and connected direct same issue.
    Possibly off on a tangent here im completely pissing in the wind. Ive some people were unable as their 800HD was an estar sim?!
    All i know is boot82,gemi5.1,sim2.10,tunner alps M.
    If anyone has had experience with similar issues and can help me out please im going nuts.
  • CoolKen
    • Feb 2012
    • 19
    Ive also tried to access via hyperterminal
    using
    hyperterminal with connection 115200 8 none 1 none and power up dreambox
    nothing blank
    • cgscott
      • 3513
      Heres are files with instructions to try. Good luck.
      Patience is a virtue.
      • CoolKen
        • Feb 2012
        • 19
        Just an upate i tried again with hyperterminal powered up and hitting enter many times, then i think i hit the 'f' key and i saw some life on hyperterminal:
        b????????????????????????????????????????????????? ?????????????b???????????
        ?????????????????????????????????????????????????c ??????????????????????????????
        ?????????????????????????????????b???????????????? ??????????????????????????????
        ?????b
        now it' booted to dhcp then booting! Now says 'system message' on front, so something works.
        • southpaw
          • 2233
          Try applying power now with "on " button pressed, hopefully your box will display an IP address, then you can flash any sim2 dm800 image to it in the normal browser method
          • CoolKen
            • Feb 2012
            • 19
            Thanks Southpaw tried this many times power held on doesn't do anything, instant error on display.
            But now ive discovered hitting the 'f' key in hyperterminal then prompts the dreambox to continue booting as if ive held power button and display shows dhcp and IP i now have flash menu via web!!
            Ok which bootloader or image can i use? As above i had Sim 2.1 with bootloader 82 for 800hd clone, can someone post me link to correct bootloader or image to fix?
            Just to add via the web interface i have below which is what i think i flashed which ****ed things up as it was 82 when it worked ok and this 84 i think was from the original dreambox de site ahem!
            ??? second stage loader #84 (2011-09-02)
            • CoolKen
              • Feb 2012
              • 19
              Update
              So now my box is backup and working.
              So for anyone else out there having this issue
              Dreambox 800hd not responding to dreamup see below:
              Requirements: Null modem cable
              Procedure (With XP and hardware serial port)
              1)Ensure dreambox is unplugged
              2) Connect dbox to com port with NULL MODEM CABLE, do not try using a gender changer on a standard usb/serial cable. (Should be com1)
              3) Fire up Hyperterminal create profile using profile
              4 Click ok to activate should see a flashing cursor in hyperterminal
              5 Power up Dreambox, wait few seconds and hit the 'f' key.
              You should see the 'Err01 no Ca found' dissapear, a few lines of garbage appear in hyperterminal window and dreambox loading onto 'STOP' looking for DHCP assigned IP.
              IP should be displayed shortly after where you can follow many other procs on here to access http://<displayed ip> and proceed with loading the correct SSL image.
              I grabbed this one
              Digital Kaos - Downloads - SSL84b for DM800 sim 2
              Then flashed a new SSL84b image which was this
              All working fine now! Ive not seen a single method online using what i did above, my discovery was nigh on fluke as i started bashing the keyboard in frustration and the ****ing thing started working mindless violence occasionally works.
              Note if you dont have XP and hyperminal. For Windows 7 you download putty under 'session - connection type - select serial and then you can select your com port there. I have not tested this with usb/serial lead. I read many things about driver issues with the maplin lead and was having so many issues with dreamup no responding i binned it using a direct com port.
              Anyway i hope this saves somebody from wasting a whole day n half pissing about with dreamup versions to find none of them work!
              cheers,
              Cool Ken aka DJ Ken (ondawunzantooos)
              • potrobber
                • Mar 2010
                • 493
                m8 only seen your post now but this might help others in future
                this link is the best tool for no ca error and other dreambox problems i have found fixs no ca error in no time
                what you went thru seems head wreaking this is a couple of clicks and job done
                use the latest as this is the first in the thread
                • LENSDEN
                  • 5
                  there is a version of dreamup v2009 patched by forhike and natas. this worked for me as i also had the same problem i am sure i found it on this forum somewhere if i can figur out how to upload it i will
                  • LENSDEN
                    • 5
                    i have uploaded the patched dreamup by forhike and natas go to downloads go to search and type in dreamup hopefully you will find it
                    • CoolKen
                      • Feb 2012
                      • 19
                      Yep see above tried that version didn't work. Thanks anyway.
                      • potrobber
                        • Mar 2010
                        • 493
                        guys the dreambox optiflasher has a no ca error button and sorts this problem in no time with no messing
                        its alot better than dreamup you just click do job and power on your dreambox and few mins later allsorted
                        • ash213
                          • Apr 2009
                          • 64
                          where can i find hyperterminal?
                          cheers
                          • CoolKen
                            • Feb 2012
                            • 19
                            cheers
                            Hi Ash do you have the 'No CA found' issue? see above Potrobber posted a link to a newer app which apparently unbricks most.
                            Saying that none of the dreamup revisions worked on mine and i tried an older app by Yassinov and it didn't work on mine.
                            Anyway in answer to your question i commented above, hyperterminal is on Windows XP its not on Windows 7. If you have windows 7 google for putty and download the .exe fie, launch putty under, 'session - connection type - select serial and then you can select your com port there.
                            Let me know how you get on. Are you using a Serial null modem cable on a com port or usb/serial with null modem attached?
                            • potrobber
                              • Mar 2010
                              • 493
                              ken
                              he tried yassanov,s flash tool and it did not work i sent him link to here for you to explain what you done
                              i have never had any problems using 1.0.6 with the no ca error always worked for me but there is always the first time good luck ash
