The dreaded 'Error 01 No CA Found'
  • CoolKen
    • Feb 2012
    • 19
    #16
    aye mate indeed like i said none of them worked for me as i dont see any output from hyperterminal on bootup (not until i hit the f key) which im guessing most of these apps are looking for some sort of signal.
    Be interested to hear what he reports back any update Ash?
    • ash213
      • Apr 2009
      • 64
      #17
      thank you both.
      just seen the posts, going to try this method this afternoon with windows 7.
      hopefully it works as i want this damn box upstairs in my office!!
      cheers both again, will report back later
      • ash213
        • Apr 2009
        • 64
        #18
        Originally posted by CoolKen
        So now my box is backup and working.
        So for anyone else out there having this issue
        Dreambox 800hd not responding to dreamup see below:
        Requirements: Null modem cable
        Procedure (With XP and hardware serial port)
        1)Ensure dreambox is unplugged
        2) Connect dbox to com port with NULL MODEM CABLE, do not try using a gender changer on a standard usb/serial cable. (Should be com1)
        3) Fire up Hyperterminal create profile using profile
        connection 115200 8 none 1 none
        4 Click ok to activate should see a flashing cursor in hyperterminal
        5 Power up Dreambox, wait few seconds and hit the 'f' key.
        You should see the 'Err01 no Ca found' dissapear, a few lines of garbage appear in hyperterminal window and dreambox loading onto 'STOP' looking for DHCP assigned IP.
        IP should be displayed shortly after where you can follow many other procs on here to access http://<displayed ip> and proceed with loading the correct SSL image.
        I grabbed this one
        Digital Kaos - Downloads - SSL84b for DM800 sim 2
        Then flashed a new SSL84b image which was this
        All working fine now! Ive not seen a single method online using what i did above, my discovery was nigh on fluke as i started bashing the keyboard in frustration and the ****ing thing started working mindless violence occasionally works.
        Note if you dont have XP and hyperminal. For Windows 7 you download putty under 'session - connection type - select serial and then you can select your com port there. I have not tested this with usb/serial lead. I read many things about driver issues with the maplin lead and was having so many issues with dreamup no responding i binned it using a direct com port.
        Anyway i hope this saves somebody from wasting a whole day n half pissing about with dreamup versions to find none of them work!
        cheers,
        Cool Ken aka DJ Ken (ondawunzantooos)
        nothing worked...
        the putty thing opened up recognised the box then just displayed lost of foreign letters etc...
        really dont know where to go from here...might bin it
        • CoolKen
          • Feb 2012
          • 19
          #19
          If you're gonna bin it ill have it
          Just a recap, what model do you have, i gather an 800hd? As you have a display?
          So you power up the device and it instantly displays Err01 no CA' ? What exactly do you see in putty? So you hit the f key or enter key and the display on the dreambox does not change?
          Have you tried all keys? Stab in the dark but, thats how where i ended up, and it worked.
          • ash213
            • Apr 2009
            • 64
            #20
            will probably have another bash at it later.
            if i open it up and unscrew it will it tell me inside what sim etc it is?
            yes when i power on i get that damn error straight away and it says something about dreambox7020.com i think?
            • ash213
              • Apr 2009
              • 64
              #21
              tried again, does bugger all. f key, nothing.
              the terminal thing just displays weierd caracters then does nothing when i hit F or any other key...damn this is getting me down now. need it sorted.
              when i hook the box up to my virgin hub it tells me the ip is 192.168.0.6 but when i put that in browser it doesnt bring up a page ffs.
              • Boxfresh
                • Feb 2012
                • 16
                #22
                Originally posted by potrobber
                m8 only seen your post now but this might help others in future
                this link is the best tool for no ca error and other dreambox problems i have found fixs no ca error in no time
                what you went thru seems head wreaking this is a couple of clicks and job done
                use the latest as this is the first in the thread
                Just to let you all know that I am just after trying this because I had the same ''No Ca error'' and it worked for me. Dreambox saved!
                • orbita75
                  • Feb 2012
                  #23
                  thanks CoolKen
                  Hi guys,
                  I tried every tool or application that is on the internet to get rid of NO CA FOUND and nothing was working, simply the DM didn't communicate with the PC or Llaptop.
                  After reading the message from CoolKen, eventhough I was thinking about that solution but didn't tried, I connected my llaptop with OS Win7 via usb to serial and then null modem cable to DM, created a new connection with the suggested speed on the putty and tried hitting the "f" key couple of times but nothing happened. Then I tried to hit some other keys also capital letters and I sow the NO CA FOUND dissapearing and the DM got an IP Address, so it was working again .
                  Thanks again CoolKen.
                  • tkm18
                    • Aug 2009
                    • 158
                    #24
                    Right after reading this im still getting nothing, when i try putty the response is 'cant open serial port'.
                    Im using the suggested the speed but getting nothing.
                    Dead serial port on the DM800 perhaps?
                    Have tried every version of dreamup and optoflasher.
                    • mast
                      • Nov 2010
                      • 1027
                      #25
                      Probably stating the obvious but have you selected the correct com port.
                      Regards
                      • tkm18
                        • Aug 2009
                        • 158
                        #26
                        Originally posted by mast
                        Regards
                        Yes, ive got putty opening now but its only firing up 1 wee symbol, an accented 'u' and thats it.
                        Dunno what to try now, been battering the life out the keyboard to try and get a response.
                        • mast
                          • Nov 2010
                          • 1027
                          #27
                          Just going out now but can you recap what youve tried so far and have you tried the optiflasher. I just used it on a friends dm800 with win7 and usb adapter and worked gr8, one click and its repaired.
                          Regards
                          • tkm18
                            • Aug 2009
                            • 158
                            #28
                            Regards
                            This box no ca'd on me a while back, tried dreamedup patched on it a couple of times, no response, stumbled across this thread today, tried it, very little response other than the 1 symbol on screen.
                            Havent tried any newer versions of optiflasher as it doesnt seem to want to run on my windows 7 setup.
                            Ive repaired a no ca a box a while back no bother using a usb2serial and dreamup, but for the life of me i cant get this one budging.
                            • mast
                              • Nov 2010
                              • 1027
                              #29
                              If thats the case then I would deffo try to do it on older lappie or desktop with a dedicated serial port and maybe even xp as the operating system.
                              Regards
                              • tkm18
                                • Aug 2009
                                • 158
                                #30
                                Ive got optiflasher 1.6, i think, running but its still not picking it up, on the putty i was using a direct serial port, shoulda said. Sorry.
                                Im really beginning to think this thing is gubbed.
