In regards to the dm800 Hd PVR im having difficulty adding the image. I tried the method of holding the power button on start-up and flashing the box via IP on desktop, now it comes up with error code on LED display as ERR01 NO CA FOUND. aslo tried flashing the box with the latest dreamup. no luck
NO CA FOUND error info in the Dreambox led display
Try other versions of dream up, If your box is a clone there is a patched version of dream up which is clone friendly and there is an app on this forum called "dreambox optiflasher" I haven't used it myself so can't comment on it, I've had the "no ca error" myself and always eventually found a dream up that worked.sigpic -
neither work for meTry other versions of dream up, If your box is a clone there is a patched version of dream up which is clone friendly and there is an app on this forum called "dreambox optiflasher" I haven't used it myself so can't comment on it, I've had the "no ca error" myself and always eventually found a dream up that worked.
Mate of mine came over with his 800hd box with no ca error, I tried several versions of dreamup and sorted it out with dreamup v2009 on winxp laptop. You can try that one hope it works for you.Comment
