USB working but not filling up
  • macdadi112
    • May 2011
    • 55
    Hiiiiiiiiiii,
    I've been using a 32Gb usb stick to record stuff on a dreambox 800hd.
    It works ok, but then after a while a message shows up saying the disk is full. I check the USB stick and it has 24 Gb left.
    Does anyone have an idea of whats going on?
    Macdadi112
  • IAmATeaf
    • 591
    Is the USB stick in FAT32 format, if it is then this has a max file size limit of 4Gb.
    • macdadi112
      • May 2011
      • 55
      Think it might be.
      So wot format does it have to be in to use the full 32Gb?
      • davvo
        • Apr 2009
        • 666
        google this plugin and it will do it for you
        enigma2-plugin-extensions-usb2hdd_0.1.6_mipsel.ipk
        • macdadi112
          • May 2011
          • 55
          Does it mean that I'll lose whatever is saved on there?
          • davvo
            • Apr 2009
            • 666
            yeah
            if you format a usb stick or hdd
            you lose what you have unless you back it up
            ftp in to the box
            and copy whats on the stick over to your pc
            • macdadi112
              • May 2011
              • 55
              I get an error message ..
              "Don't try and use it in an image without usb drivers in kernel, sorry"
              There must be a way I can do it on my pc??
              What format does it have to be in?
              • davvo
                • Apr 2009
                • 666
                linux ext3
                use the plugin above it will do it for you in 2 secs
                put the plugin in tmp go to dm addons manual install
                or download Gparted make a boot disc
                then format with Gparted
