Dreambox 800 HD
  • aloushi
    • Feb 2012
    • 8
    Dreambox 800 HD
    Hello,iam having a serious problem and i need help!!!
    So my problem is that yesterday my small brother was playinh with the remote and he did something,so that know we are now unable to watch TV,so i had a look at the Sattelittes there are no sattelites it is empty so i open my pc and tried to add a new one through DCC E2 in etc/enigma2 and in enigma2/tvxox but no luck,so i entered my pugin menu on the reciever and downloaded a hespisat plugin and entered the HESPISAT SAT only appeared so i went back to DCC and saw that nth have changed in ENIGMA2 i erased evrything still they appeared and worked so i guess it is stored somewhere else where could it be pls help me !! and what could be the solution pls help as soon as possible
    Thnx in advance !!!
    Have you checked the Radio button hasn't been pressed instead of TV.
    • aloushi
      • Feb 2012
      • 8
      Yes of course i did (: any other suggestions ?
        You could just reupload your settings again using Dreamboxedit
        • aloushi
          • Feb 2012
          • 8
          what do you mean pls be more specific (:
          • bends
            • 57
            dreamboxedit is software for editing and sending new bouquets/channels to your box. you can download it on this site, then configure it to be able to connect to your box.
            you then get a list of those channels from somewhere like sgtflipflop or vhannibal etc related to what you want to see (which sats you can see).
            you load these into dreamboxedit, then use dbedit to send these (collectively known as settings) to your dreambox.
            after an update the new channels appear.
            btw, have you checked that your tuner config is still ok. not been changed to disecq switch or positioner set wrong...
            menu>setup>sat searching...
            finally, if you are spending ages on this, a relatively quick fix is to reflash your box - you do have a backup dont you
            • aloushi
              • Feb 2012
              • 8
              Thnx very much bro i fixed it !!
              • bends
                • 57
                good news.
                what did fix it in the end? let us know as it may be useful for someone els in the same boat!
                cheers.
                • aloushi
                  • Feb 2012
                  • 8
                  good news.
                  cheers.
                  Well, to start i had a problem with Sattelites.xml and for others who have the same problem i would recommend them to reinstall Enigma2 and always use DREAMBOXEDIT Because the DCC doesnt work all the time,thnx
                  Best regards
                  close the topic (:
