No CA FOUND.................HELP!!!!!
  • k8ty
    • Apr 2012
    • 11
    Hi all, Just flashed my 800hdse clone with a dreamboxuk image, pressed reboot and got "R01 no ca found" on the little screen.
    What do i do now???
    K8ty
  • digicon
    • 8261
    Can you remember what bootloader your box was on before you flashed the DBUK image, as you will have to use the Sunray flashup tool to get another image on your box.
    • benny/9
      • 1964
      What do i do now???
      K8ty
      clear the box this way mate.
      Items required:
      A TO B mini-usb male to male [same as a camera USB] & Cat5 Network Cable
      these long A to B camera cables are available at maplins if you dont have one
      [if your model is a clone use the sunray version of dreamup]
      Process:
      1)first on the Dream 500HD/dm800se turn off with the switch on
      the rear panel
      2)next connect the cable for its part mini-usb port and
      "Service" of the Dream 500HD and the USB to a USB port on your PC
      and also the Lan Cable from your Router
      3)Just plug it in, the PC will detect new hardware connected to the system:
      4)The PC will ask the driver for this new component,
      Windows 7 will download the driver Automaticly for you
      the driver is cp210x usb to uart bridge controller
      5)Open the Windows Device Manager,
      and you will see the new hardware installed,
      will appear as COM port (even a USB cable).
      In the following example, is recognized as the cable into the port COM4.
      6)next opened the universal DreamUP 1.3.3.9 [this is the latest version]
      and select the update COM port (like any other model of Dreambox).
      At this point, we choose the COM port that we appeared in the previous step
      (COM4 in this example).and make sure there is a tick in the use network box
      7)Press the Connect button the DreamUP universal panel and then go to the
      dreambox and power it up to turn on again now the Dream 500HD/800se will
      now to start up loading firmware.and once compleated the dreamup loader will
      go in to HTTP mode you then click the flash button and find the correct image
      then on the window click open and it will load on the dreamup and load on your
      dreambox once fully loaded exit the loader and turn your dreambox off and on
      again at the rear switch now the image will boot and you can the configure the box
      Please Read Carefully!
      • k8ty
        • Apr 2012
        • 11
        hi, I found dreamup.... but no "universal dreamup"
        sorry for being so thick!
        • k8ty
          • Apr 2012
          • 11
          cant remember what bootloader it was either. Just what it came out the factory with
          • digicon
            • 8261
            Then it will be more than likely 82a find an image with a bootloader of 82a and flash that back on and it should be ok, any future images with a different bootloader you flash the bootloader first and before you switch off the 800se you flash the image staright after.
            I think you need to do some Guide reading
            • k8ty
              • Apr 2012
              • 11
              Bootloader is R84
              • digicon
                • 8261
                Bootloader is R84
                If its a Sim2 box there are no R84 images latest bootloader is 84b, If its a Ferrari sim then latest bootloader is 87f
                • k8ty
                  • Apr 2012
                  • 11
                  it is a sim 2 box. so do you have any idea of an image i can put on?
                  Thanks for being so helpfull
                  • barrox
                    • Apr 2012
                    Had the same problem, CA not Found on my DM 800 clone after flashing my new box that came in on Saturday. Managed to revive it using Null Modem to USB cable and DreamUP. Flashed with Nemesis v2.5 (enigma2 image). Works fine now
                    But use USB to USB cable as per benny/9 post, I didn't know this works - as it should be easier to get then Null Modem cable.
                    Mine is also sim2.1 box with bootloader 84
                    Good luck
                    • lombard
                      • Aug 2008
                      • 793
                      Hi, is it the new dm800se with the mini flash button at the back,
                      if yes no need for mini usb or dreamup, just hold mini flash button, replug in power, will get IP address, then flash as normal
                      what you should have done with the dbuk image is flash but dont restart, then flash bootloader 84b , then restart and will go through fine
                      • madaboutlotus
                        • Feb 2012
                        • 27
                        Good luck
                        Hi barrox
                        Similar issue when I tried to flash a new image on my clone after having lots of issues with the current image. Do I follow the same procedure as benny/9 just with the null modem cable? Does the Nemesis function OK with the clone, I guess it does.
                        • alom5
                          • 1648
                          majority of the patched images have bootloader on them already.......also, if you had a image with #82 bootloader...does not mean you can flash only images with #82 bootloader.
                          you can flash any image. the images in the downloads section here will say on the title the bootloader version and i'm sure most of them have bootloader already on them so no need to flassh bootloader separately after flashing image.
                          i haven't checked every image in downloads section....but......all the images i have uploaded contain bootloader on them already tha's for sure....
