ethernet port not working after recovering a no ca error on dm800
  • colinh1213
    • Apr 2011
    • 92
    after getting a no ca error on a dm800 , i sorted it out with null cable and ethernet on dreamup , now the ethernet port is not working, tried all settings, new poewr supply , ethernet cable, but no joy, anybody got any clues, i was on openplibup image with boot 82 before the ca error. flashed with different images including this one but still no joy. any help appreciated guys, thanks.
  • DOUGALMCD
    • May 2011
    • 3229
    Have you checked ethernet pins are ok at rear of box.
    • colinh1213
      • Apr 2011
      • 92
      yes mate, done all the checks inside and out of box.
      • DOUGALMCD
        • May 2011
        • 3229
        Do the ethernet lights stay on at back of box when connected or just at start up.There is a thread relating to no ca error fix by bonesey in cable section. hope this helps.
        • colinh1213
          • Apr 2011
          • 92
          come on for 1 sec on start up then go out. its the first time i have ever come across this one.
          • DOUGALMCD
            • May 2011
            • 3229
            This may help also. dm800 no ethernet lights solution in www. sat planet.
            • colinh1213
              • Apr 2011
              • 92
              still no joy , all looks good , what a pain in the ass.
              • Fergal
                • 1007
                Are connecting via your router or straight from pc to box as you need to use a crossover ethernet cable if your connecting from pc straight to your box.
                • colinh1213
                  • Apr 2011
                  • 92
                  router to box and null to pc , its the easiest way of flashing a no ca error,
                  • colinh1213
                    • Apr 2011
                    • 92
                    but after ive flashed it ethernet port wont work .
