DM800HDse power on problem
  • DelphiCoder
    • Apr 2012
    • 11
    Hi all
    my DM800HDse won't power on. I can see the red and green led lit inside the box but nothing on the TV the fan doesn't turn and the OLED screen is black.
    please any suggestions
  • smirnoff_rules
    • 8603
    ? hopefully its just a power brick, they can show power but no amps , had a few faulty ones other the years
    • DelphiCoder
      • Apr 2012
      • 11
      how can I test this power adapter
      • smirnoff_rules
        • 8603
        multi meter ,, or have u another 12v brick ,,ie from your router or something to for a quick try , but dont use all the time if it works because u need a 12v 3 amp unit
        • DelphiCoder
          • Apr 2012
          • 11
          I tried my router's one same results, but it's only 0.5A
          • lombard
            • Aug 2008
            • 793
            Hi, i had this if i had power in dm800se and turned off and tried again right away , just green and red led on inside, noting oled, by switching button at back on and off very quickly gets it working again
            • DelphiCoder
              • Apr 2012
              • 11
              Hi all
              Today, I tried 3 models of bricks (12 v, 3-4 A) and nothing happened. I tried lombard's trick and the DM is styill black. what I noticed is that the inside LEDs are lit I mean the green one (tuner's LED) and a row of 5 red LEDs except the 3rd red one. I tried to switch the DM after removing the tuner : NO NEWS.
              HELP is NEEDED
              • DelphiCoder
                • Apr 2012
                • 11
                ANY IDEA?????????????????
                • DelphiCoder
                  • Apr 2012
                  • 11
                  PLS HELP, ANY IDEA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                  • 00360362878
                    • Mar 2010
                    • 488
                    Do any of the capacitors look discolored or bulging at the top, if they are, might be worth replacing them, if your ok with a soldering iron. They cost pennies.
                    you can put a test on them with a multimeter if you know how, but if not, take the board to maplin's, they wont test it but they may tell better than you if it's worth replacing them.
                    Not saying that's your answer, but if you don't have anywhere to turn, its cheap to do and something else to eliminate.
                    • IAmATeaf
                      • 591
                      Is this a new box or an old one that's stopped working?
                      • DelphiCoder
                        • Apr 2012
                        • 11
                        1. I can't see any damaged capcitor
                        2. no it's a new one that worked one week
