SD S*y UK Boquet
  • Bann32
    • Oct 2011
    • 518
    SD S*y UK Boquet
    I have attempted to convert a bouquet from Enigma2 to Enigma1. I have removed the HD channels and replaced them with thier HD Counterparts and the numbering has been done to mimic the default sky channel numbers.
    I don't even know if you can convert a bouquet from E2 to E1, but in any event I can't get it to work...
    I have attached my attempt so far, in case someone is able to finish it off or point out where I am going wrong.
  • smoggie
    • 863
    why not just use sgt flipflops enigma1 bouquets?
    • Bann32
      • Oct 2011
      • 518
      Well until it didn't work this way seemed it would be quicket to exactly mimic the channel numbering used by sky and to use Sgtflipflops boquet and start from again is not a task im up to at the moment.
      • potrobber
        • Mar 2010
        • 493
        banny as i said on other site i dont think you can use enigma 2 lists on enigma 1 box sgt flip flop might now how to do it if it can be done
        the best place to ask here is on sgt flip flops thread if anyone can tell you im sure he can
        tell you if it will work
        • betas
          • 52
          dm 500 tm 500/600 ch list
          dm 500 tm 500/600 ch listHave a look at this
          • RuberDuck
            • 1724
            bouquets like these have been produced for many years for example
            you can either use the Silverfox0786 sky uk bouquet which also follows the sky uk channel numbering exactly as a sky box does or use the B16MCC front end program to create your own sky uk bouquets as and when you want, as it connects to the DBUK server and creates the bouquet from a always updated excel spreadsheet keeping the bouquets created as upto date as it is possible to get.
