how do i get an epg on my dreambox800 hd and how do i put channels in order like a sly box as my channels are all in alphabetical order with no catergories....
dreambox 800 hd epg and channel order
Use SGTFlipFlops latest bouquets >>> http://www.digital-kaos.co.uk/forums...ml#post1532148
And install CrossEPG and Cool TV Guide -
If you go to satellites xml generater, there you can put your required sat file together, download the file to your desktop, and drop the file into tuxbox folder via your choice of ftp. I use core ftp, but most use dcc.Comment
All you do is go to satellite xml generator site, tick the sats you want to use, then download the xml file to your pc.
Then use a file transfer program to drop the file in into your tuxbox folder normally in var/etc/enigma2, then overwrite your sat xml file.
exit the program and reboot the box, you should then see the sat's you intend to use.Comment
